メインコンテンツにスキップ
HomePod Mini Speaker Replacement
必要な工具と部品
    • turn homepod mini upside down
    • peel back the foot cover
    • carefully cut the fabric mesh using the fabric scissors
    • be very careful not to scratch the delicate glass surface on top
    • unscrew the 4 torx screws on the bottom near the speaker holes
    • carefully seperate the top and middle sections from the homepod mini
    • be very careful when separating as there are cables connected to the motherboard as well as the speakers
    • carefully unplug all the cables connected to the motherboard
    • carefully separate the middle section of the homepod mini
    • carefully remove the speaker driver from the bottom part of the homepod mini
    • be very careful not to damage the delicate ribbon cable below the driver
    • remove the speaker driver
    • carefully remove the cables connecting to the driver being careful not to damage it
終わりに
作成者
2人の作成者と共同で作成されました。
776831
メンバー登録日: 06/10/21
1,034 ポイント
8のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 37
過去 30 日: 136
今までの合計 2,295
