はじめに
If the arm of the drone is having trouble opening or is broken, you will need to replace the arm. The arm of the drone holds the propeller blades and allows the propeller to spin, without the arm the drone is inoperable.
The only tool needed to replace the arm is a Phillips #0 screwdriver. This replacement is simple and prompt, these are the steps to accomplish this task.
必要な工具と部品
もう少しです!
終わりに
