メインコンテンツにスキップ
Holmes HEH8031 Control Buttons Replacement
必要な工具と部品
  1. Holmes HEH8031 Control Buttons Replacement, Housing: 手順 1、 1の画像 1
    • Ensure the device is unplugged from the wall outlet.
  2. Holmes HEH8031 Control Buttons Replacement: 手順 2、 1の画像 1
    • Remove eight 12-mm Phillips #2 screws from the back cover.
  3. Holmes HEH8031 Control Buttons Replacement: 手順 3、 2の画像 1 Holmes HEH8031 Control Buttons Replacement: 手順 3、 2の画像 2
    • Turn heater over so the controls are facing up.
    • Lift the front housing away from the back of the fan and slowly fold the front housing back down to the floor.
    • Internal wires are connected to both halves of the housing. Be careful when separating the housing.
  4. Holmes HEH8031 Control Buttons Replacement, Circuit Board Removal: 手順 4、 1の画像 1
    • Remove four 12mm Phillips #2 screws from the circuit board.
  5. Holmes HEH8031 Control Buttons Replacement, Control Buttons: 手順 5、 3の画像 1 Holmes HEH8031 Control Buttons Replacement, Control Buttons: 手順 5、 3の画像 2 Holmes HEH8031 Control Buttons Replacement, Control Buttons: 手順 5、 3の画像 3
    • Remove the two Phillips #2 12mm screws from the button retainer.
    • Lift the button retainer off.
    • Remove the interconnected buttons.
    • If the buttons are broken, replace them.
    • If the buttons are sticking, clean them in warm soapy water and allow to dry.
  6. Holmes HEH8031 Control Buttons Replacement: 手順 6、 3の画像 1 Holmes HEH8031 Control Buttons Replacement: 手順 6、 3の画像 2 Holmes HEH8031 Control Buttons Replacement: 手順 6、 3の画像 3
    • Using light finger pressure, carefully push the black plastic tabs off the white plastic hooks.
    • Remove the black plastic bracket out through the front of the heater housing.
    • Remove the two Phillips #2 12mm screws and remove the clear window from the black plastic bracket.
    • If the buttons were sticking, clean the black plastic bracket in warm soapy water and allow to dry.
    • If the clear window was dirty, clean it in warm soapy water and allow to dry.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Chris Shaffer
メンバー登録日: 10/12/16
255 ポイント
2のガイドは作成済み
チーム
IUPUI, Team 2-1, Baechle Fall 2016 IUPUI, Team 2-1, Baechle Fall 2016人のメンバー
IUPUI-BAECHLE-F16S2G1
4 メンバー
16のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 487
