メインコンテンツにスキップ
Hockey Helmet Cage Replacement
必要な工具と部品
  1. Hockey Helmet Cage Replacement, Cage: 手順 1、 3の画像 1 Hockey Helmet Cage Replacement, Cage: 手順 1、 3の画像 2 Hockey Helmet Cage Replacement, Cage: 手順 1、 3の画像 3
    • Unscrew the hinge clips from the front of the helmet.
    • This separates the old cage from the helmet.
  2. Hockey Helmet Cage Replacement: 手順 2、 3の画像 1 Hockey Helmet Cage Replacement: 手順 2、 3の画像 2 Hockey Helmet Cage Replacement: 手順 2、 3の画像 3
    • Replace the screw clips on the sides of the helmet with the ones from the new cage.
    • Different companies have different sized clip screws so it is important to install the new ones that come with your cage.
  3. Hockey Helmet Cage Replacement: 手順 3、 3の画像 1 Hockey Helmet Cage Replacement: 手順 3、 3の画像 2 Hockey Helmet Cage Replacement: 手順 3、 3の画像 3
    • Clip the new hinge clips onto the top center of the new cage.
    • Make sure the flat side of the hinge is facing towards the inside of the cage, and that it is pointed upward.
  4. Hockey Helmet Cage Replacement: 手順 4、 3の画像 1 Hockey Helmet Cage Replacement: 手順 4、 3の画像 2 Hockey Helmet Cage Replacement: 手順 4、 3の画像 3
    • Align the hinge holes with the screw holes in the center of the helmet.
    • Once everything is lined up, screw the hinges into the holes in the helmet to attach the cage to the helmet.
  5. Hockey Helmet Cage Replacement: 手順 5、 3の画像 1 Hockey Helmet Cage Replacement: 手順 5、 3の画像 2 Hockey Helmet Cage Replacement: 手順 5、 3の画像 3
    • Make sure now that the cage is on that it has full range of motion.
    • It should fit under the J clips on the sides of the helmet when pushed up.
    • It should be able to extend 90 degrees outward.
  6. Hockey Helmet Cage Replacement: 手順 6、 3の画像 1 Hockey Helmet Cage Replacement: 手順 6、 3の画像 2 Hockey Helmet Cage Replacement: 手順 6、 3の画像 3
    • Now tighten the straps on either side of the cage.
    • Clip the straps into the screws on either side of the helmet to check how tight it is.
    • The straps should be tight to the screw clip, and the cage should be touching the j-clip.
    • Once you do this and you put the helmet on, if your chin is sitting perfectly in the chin guard, the helmet and cage will not move from their position if you shake or nod your head.
終わりに
Make sure all of the screws are tight, and you have just completed the replacement of the hockey helmet cage!
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Blake Donovan
メンバー登録日: 01/16/21
195 ポイント
1ガイドが承認済み
チーム
York University, Team S1-G4, Woodhouse Winter 2021 York University, Team S1-G4, Woodhouse Winter 2021人のメンバー
YORK-WOODHOUSE-W21S1G4
1 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 29
過去 30 日: 126
今までの合計 5,985
