メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
The bread pan seal keeps the dough on the inside of the bread pan and oil from the axel away from your sweet sweet bread. After prolonged use the seal can crack and split which makes it ineffective and requires replacement.
  1. First, open up the home bakery and remove the bread pan. First, open up the home bakery and remove the bread pan.
    • First, open up the home bakery and remove the bread pan.
  2. Pull the paddle/mixer out from inside the bread pan.
    • Pull the paddle/mixer out from inside the bread pan.
  3. 全てのタブを開く
    Mac用RAMアップグレードキット
    キット商品を見る
    どれだけタブを開いても
    十分に足りるRAM容量
    キット商品を見る
  4. Flip the bread pan over and locate the "C" shaped clip. Orient the clip so the ends line up with the flat part of the bolt. Using tweezers or "C" clip pliers, pry the clip apart and remove it. Flip the bread pan over and locate the "C" shaped clip. Orient the clip so the ends line up with the flat part of the bolt. Using tweezers or "C" clip pliers, pry the clip apart and remove it. Flip the bread pan over and locate the "C" shaped clip. Orient the clip so the ends line up with the flat part of the bolt. Using tweezers or "C" clip pliers, pry the clip apart and remove it.
    • Flip the bread pan over and locate the "C" shaped clip. Orient the clip so the ends line up with the flat part of the bolt. Using tweezers or "C" clip pliers, pry the clip apart and remove it.
  5. Once the clip is removed, the wing washer and circular washer can be easily removed by hand or tweezer. Once the clip is removed, the wing washer and circular washer can be easily removed by hand or tweezer.
    • Once the clip is removed, the wing washer and circular washer can be easily removed by hand or tweezer.
  6. Use a rubber mallet or other blunt object to push the bolt until it is flush with the seal. Use a rubber mallet or other blunt object to push the bolt until it is flush with the seal.
    • Use a rubber mallet or other blunt object to push the bolt until it is flush with the seal.
  7. Flip the bread pan over and remove the bolt by hand or plyers if necessary. Remove the seal and replace with a new one. Make sure the seal is oriented the correct direction (refer to the picture) Flip the bread pan over and remove the bolt by hand or plyers if necessary. Remove the seal and replace with a new one. Make sure the seal is oriented the correct direction (refer to the picture) Flip the bread pan over and remove the bolt by hand or plyers if necessary. Remove the seal and replace with a new one. Make sure the seal is oriented the correct direction (refer to the picture)
    • Flip the bread pan over and remove the bolt by hand or plyers if necessary. Remove the seal and replace with a new one. Make sure the seal is oriented the correct direction (refer to the picture)
終わりに
ある他の人がこのガイドを完成しました。
Casey Smith
メンバー登録日: 2017年01月25日
125 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 9-2, Banghart Winter 2017 Cal Poly, Team 9-2, Banghart Winter 2017人のメンバー
CPSU-BANGHART-W17S9G2
3 メンバー
5のガイドは作成済み
2 件のコメント
Very helpful, thanks,
Just one question.
Where do you find the Shaft Seal?
Do you know if the Shaft seal bread maker you use for, is adequate for food uses?
This seal is approved by NSF/ANSI Standard 51 - Food Equipment Materials?
https://standards.nsf.org/apps/group_pub...
Luissm - 返信
What kind of grease should I use to lubricate the shaft? If the “C” clip gets away from me and gets lost, what is the diameter of the recessed part of the shaft that the clip attaches to, so that I know what size clip to buy as a replacement?
Andrew SCHWARTZ - 返信
コメントを追加
統計データを表示:
過去 24時間: 3
過去 7 日: 22
過去 30 日: 43
今までの合計 1,113
