メインコンテンツにスキップ
Hitachi ED-A101 mirror moving system replacement
必要な工具と部品
特集記事
  1. Hitachi ED-A101 mirror moving system replacement, Limit switches: 手順 1、 1の画像 1
    • There are two limit switches on the axe of the mirror reporting the opening and the closing of the mirror to the projector's processor (shown with our cables soldered to it).
  2. Hitachi ED-A101 mirror moving system replacement, Motor and cooling fan output: 手順 2、 1の画像 1
    • Also, the DC motor's and the cooling fan's output pins are marked on this image.
    • The cooling fan output is used to power the Arduino: it outputs 7-12V depending on the cooling needed. Although Arduino Pro Micro has a RAW input which should handle this range, it turned out that it is too much for it. So we connected the cooling fan's output to Arduino's RAW input through a voltage regulator, which outputs 5.25V.
    • The DC motor output is used to detect when the projector tries to open or close the mirror: it outputs 12V and changes the sides of the + and - depending on the direction. We connected the two diode-protected stepdown converters' input to the red and black cables of the DC motor output, and the converters' output to the input pins of the Arduino.
  3. Hitachi ED-A101 mirror moving system replacement: 手順 3、 1の画像 1
    • Circuit diagram
ゴール
添付文書
作成者
1人の作成者と共同作成されました。
Geza Makay
メンバー登録日: 11/17/18
97 ポイント
1ガイドが承認済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 7
今までの合計 372
