Using the PH#00 screwdriver, remove the two 0.145 inch Phillips head screws.
The screws are located on the bottom face of the device, near the power and volume controls.
Place the small suction cup on your screen.
Moisturize the bottom of the suction cup to ensure a proper seal.
If the screen is cracked, the suction cup may not seal correctly; too much pressure may crack or damage the screen.
Slide the plastic opening tool along device edge to separate the screen cover from the rear cover.
Pull upward on the small suction cup handle while sliding the opening tool.
When sliding the plastic opening tool, avoid sliding the tool too far into the cover. This could damage the speaker connector on the back cover.
Use the plastic opening tool to remove the speaker from the rear cover.
The speaker is held in place with adhesive and is easily removed.
Do not pull on the speaker wires. This could damage the soldering connections.
Using a solder removal tool, remove the speaker soldered connectors.
Solder the new speaker wire connections to circuit board.
First solder the red wire on the left, then the black wire on the right.
Solder can burn you. Use caution.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
