メインコンテンツにスキップ
Hipstreet Titan 2 HD Rear Case Replacement
必要な工具と部品
  1. Hipstreet Titan 2 HD Rear Case Replacement, Rear Case: 手順 1、 1の画像 1
    • Using the PH#00 screwdriver, remove the two 0.145 inch Phillips head screws.
    • The screws are located on the bottom face of the device, near the power and volume controls.
  2. Hipstreet Titan 2 HD Rear Case Replacement: 手順 2、 1の画像 1
    • Place the small suction cup on your screen.
    • Moisturize the bottom of the suction cup to ensure a proper seal.
    • If the screen is cracked, the suction cup may not seal correctly; too much pressure may crack or damage the screen.
  3. Hipstreet Titan 2 HD Rear Case Replacement: 手順 3、 1の画像 1
    • Insert the plastic opening tool between the screen cover and rear cover of the tablet.
    • Grasp the small suction cup.
  4. Hipstreet Titan 2 HD Rear Case Replacement: 手順 4、 2の画像 1 Hipstreet Titan 2 HD Rear Case Replacement: 手順 4、 2の画像 2
    • Slide the plastic opening tool along device edge to separate the screen cover from the rear cover.
    • Pull upward on the small suction cup handle while sliding the opening tool.
    • When sliding the plastic opening tool, avoid sliding the tool too far into the cover. This could damage the speaker connector on the back cover.
  5. Hipstreet Titan 2 HD Rear Case Replacement: 手順 5、 2の画像 1 Hipstreet Titan 2 HD Rear Case Replacement: 手順 5、 2の画像 2
    • Use the plastic opening tool to remove the speaker from the rear cover.
    • The speaker is held in place with adhesive and is easily removed.
    • Do not pull on the speaker wires. This could damage the soldering connections.
  6. Hipstreet Titan 2 HD Rear Case Replacement: 手順 6、 1の画像 1
    • Once the speaker is disconnected, the cover removal is complete.
終わりに
Congratulations your tear down is complete. To reassemble your device, follow these instructions in reverse order.
ある他の人がこのガイドを完成しました。
作成者
9人の作成者と共同で作成されました。
Jeffrey
メンバー登録日: 03/11/15
766 ポイント
5のガイドは作成済み
チーム
Colorado Springs, Team 5-6, Panko Spring 2015 Colorado Springs, Team 5-6, Panko Spring 2015人のメンバー
UCCS-PANKO-S15S5G6
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 590
