メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
Once you have disassembled the tablet cover, you can now access all of the internal components. This is a simple process and will require a replacement camera to complete.
パーツ
パーツは指定されていません。
  1. Using the PH#00 screwdriver, remove the two 0.145 inch Phillips head screws.
    • Using the PH#00 screwdriver, remove the two 0.145 inch Phillips head screws.
    • The screws are located on the bottom face of the device, near the power and volume controls.
  2. Place the small suction cup on your screen.
    • Place the small suction cup on your screen.
    • Moisturize the bottom of the suction cup to ensure a proper seal.
    • If the screen is cracked, the suction cup may not seal correctly; too much pressure may crack or damage the screen.
  3. Insert the plastic opening tool between the screen cover and rear cover of the tablet.
    • Insert the plastic opening tool between the screen cover and rear cover of the tablet.
    • Grasp the small suction cup.
  4. Slide the plastic opening tool along device edge to separate the screen cover from the rear cover. Pull upward on the small suction cup handle while sliding the opening tool.
    • Slide the plastic opening tool along device edge to separate the screen cover from the rear cover.
    • Pull upward on the small suction cup handle while sliding the opening tool.
    • When sliding the plastic opening tool, avoid sliding the tool too far into the cover. This could damage the speaker connector on the back cover.
  5. Use the plastic opening tool to remove the speaker from the rear cover. The speaker is held in place with adhesive and is easily removed.
    • Use the plastic opening tool to remove the speaker from the rear cover.
    • The speaker is held in place with adhesive and is easily removed.
    • Do not pull on the speaker wires. This could damage the soldering connections.
  6. Once the speaker is disconnected, the cover removal is complete.
    • Once the speaker is disconnected, the cover removal is complete.
  7. Use your plastic opening tool to lift the black ribbon connector lock. Then, proceed to remove the camera.
    • Use your plastic opening tool to lift the black ribbon connector lock.
    • Then, proceed to remove the camera.
  8. Once the camera with the ribbon connector is removed, the process is complete.
    • Once the camera with the ribbon connector is removed, the process is complete.
終わりに
2 の人々がこのガイドを完成させました。
Jeffrey
メンバー登録日: 2015年03月11日
766 ポイント
5のガイドは作成済み
チーム
Colorado Springs, Team 5-6, Panko Spring 2015 Colorado Springs, Team 5-6, Panko Spring 2015人のメンバー
UCCS-PANKO-S15S5G6
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 307
