はじめに
This guide will show you how to remove the Heyday Wireless Speaker 8125 grille. You must remove the grille in order to access the inner components of this device so it's a requirement for all repair guides. The grilled protects the inside of the speaker while allowing the components to get air.
Before beginning this repair, power off the device and disconnect it from the charger.
必要な工具と部品
Orient the speaker so that it is sitting upright.
Use your nondominant hand to hold the speaker in place while you firmly push the plastic spudger into the seam between the device wall and the grille.
Push down with the plastic spudger and lift the grill until you feel it separate from the speaker.
Gently remove it from the top of the device.
