メインコンテンツにスキップ
Heyday Active Noise-Canceling Wireless Headphones 0398 Battery Replacement
必要な工具と部品
  1. Heyday Active Noise-Canceling Wireless Headphones 0398 Battery Replacement, Ear-pad Cushion: 手順 1、 2の画像 1 Heyday Active Noise-Canceling Wireless Headphones 0398 Battery Replacement, Ear-pad Cushion: 手順 1、 2の画像 2
    • Position the headphones so that you can see the opening for the cushion as you take out your blue iFixIt opening tool. In between the earpad cushion and the headset, place the iFixit opening tool.
  2. Heyday Active Noise-Canceling Wireless Headphones 0398 Battery Replacement: 手順 2、 1の画像 1
    • The connectors that the cushion snaps into place are used to attach the cushion to the headset. The connectors could be damaged by applying too much force, which would prevent the cushion from returning to its original position.
  3. Heyday Active Noise-Canceling Wireless Headphones 0398 Battery Replacement: 手順 3、 1の画像 1
    • After the earpad cushion has been disconnected from the connectors you can take your new earpad cushion and install it.
  4. Heyday Active Noise-Canceling Wireless Headphones 0398 Battery Replacement, Battery: 手順 4、 2の画像 1 Heyday Active Noise-Canceling Wireless Headphones 0398 Battery Replacement, Battery: 手順 4、 2の画像 2
    • After removing the ear pad cushion, unscrew the four 1.6mm black screws with your Phillips-head screwdriver.
  5. Heyday Active Noise-Canceling Wireless Headphones 0398 Battery Replacement: 手順 5、 2の画像 1 Heyday Active Noise-Canceling Wireless Headphones 0398 Battery Replacement: 手順 5、 2の画像 2
    • Use the Phillips-head screwdriver to remove the black casing screws.
    • Lift the casing to see the battery.
  6. Heyday Active Noise-Canceling Wireless Headphones 0398 Battery Replacement: 手順 6、 1の画像 1
    • The central spherical piece of metal is the battery. Use the ifixit opening tool and pry open the battery in your direction to remove the battery.
終わりに
作成者
2人の作成者と共同で作成されました。
Christopher Puperi
メンバー登録日: 09/13/23
493 ポイント
5のガイドは作成済み
チーム
Austin Community College, Team 8-3, Watkins Fall 2023 Austin Community College, Team 8-3, Watkins Fall 2023人のメンバー
AUSTINCC-WATKINS-F23S8G3
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 11
今までの合計 113
