メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Health o Meter HDR743 digital bathroom scale - LED Display Replacement
必要な工具と部品
  1. Health o Meter HDR743 digital bathroom scale - LED Display Replacement, LED Display: 手順 1、 1の画像 1
    • Open front cover of scale.
    • Examine the edges of the LED display to see if there are broken or missing solder connections with the circuit board.
    • If there are broken solder connections, re-solder the existing display to the board and skip the remaining steps. Otherwise, the LED display needs to be replaced to correct display issues, so proceed with the remaining steps.
  2. Health o Meter HDR743 digital bathroom scale - LED Display Replacement: 手順 2、 1の画像 1
    • Use a soldering iron to separate each of the connections between the circuit board and LED display. Once all of the connections are removed, pull away the broken LED display from the circuit board.
    • Remove unnecessary solder from the old connections so that each connection is separate. Leave a small amount of solder on the board to help make new connections.
  3. Health o Meter HDR743 digital bathroom scale - LED Display Replacement: 手順 3、 1の画像 1
    • Solder several connections between the new LED display and the circuit board.
    • Do not let any of the connections touch each other or the display will not function correctly.
  4. Health o Meter HDR743 digital bathroom scale - LED Display Replacement: 手順 4、 1の画像 1
    • To reassemble, securely replace the cover of the scale.
    • Test the LED display by stepping on the scale. If there are still errors in the display, check your connections and repeat soldering steps if needed.
終わりに
Once reassembled and tested, if the new LED display does not work and no connection issues are seen, then it may be the circuit board. In that case, see Circuit Board Replacement.
2 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Travis Floyd
メンバー登録日: 04/01/18
527 ポイント
2のガイドは作成済み
チーム
University of Memphis, Team S1-G1, Kim Spring 2018 University of Memphis, Team S1-G1, Kim Spring 2018人のメンバー
UM-KIM-S18S1G1
3 メンバー
4のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 24
今までの合計 517
