メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
パーツ
パーツは指定されていません。
  1. Connect a voltmeter at the power supply’s connection to the circuit board and the power supply.
    • Connect a voltmeter at the power supply’s connection to the circuit board and the power supply.
    • If the the voltage at the power supply is incorrect, the power supply should be replaced.
  2. Use wire strippers to cut the wired connection to the power supply.
    • Use wire strippers to cut the wired connection to the power supply.
    • If the wires need replacing, you will need to use a soldering iron and remove the connections at the board.
  3. Nintendo Switch 修理キット
    ゲームを再開するための、早くて簡単な修理キット
    Switch 修理キットページへ
    Switch 修理キットページへ
  4. Use the wire strippers to cut off the rubber ends of the power supply wires.
    • Use the wire strippers to cut off the rubber ends of the power supply wires.
    • Use a soldering iron and solder to fuse the connections between the two wires.
  5. Test the power supply once the wires have been reconnected. If the Health o Meter still has power issues, check the connections between the new power supply and the board.
    • Test the power supply once the wires have been reconnected.
    • If the Health o Meter still has power issues, check the connections between the new power supply and the board.
    • If no issues are found, the circuit board may need to be replaced.
終わりに
Dennis White Jr
メンバー登録日: 2018年04月02日
217 ポイント
2のガイドは作成済み
チーム
University of Memphis, Team S1-G1, Kim Spring 2018 University of Memphis, Team S1-G1, Kim Spring 2018人のメンバー
UM-KIM-S18S1G1
3 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 6
今までの合計 61
