メインコンテンツにスキップ
Harman Kardon Onyx Studio 2 Circuit Board Replacement
必要な工具と部品
  1. Harman Kardon Onyx Studio 2 Circuit Board Replacement, Front Panel: 手順 1、 3の画像 1 Harman Kardon Onyx Studio 2 Circuit Board Replacement, Front Panel: 手順 1、 3の画像 2 Harman Kardon Onyx Studio 2 Circuit Board Replacement, Front Panel: 手順 1、 3の画像 3
    • Using a plastic opening tool, pry off the front grill by wedging it in the notch on the front of the device.
  2. Harman Kardon Onyx Studio 2 Circuit Board Replacement: 手順 2、 2の画像 1 Harman Kardon Onyx Studio 2 Circuit Board Replacement: 手順 2、 2の画像 2
    • Remove the five 14.4 mm T10 Torx screws.
  3. Harman Kardon Onyx Studio 2 Circuit Board Replacement: 手順 3、 1の画像 1
    • Gently pull the front apart from the back.
  4. Harman Kardon Onyx Studio 2 Circuit Board Replacement: 手順 4、 2の画像 1 Harman Kardon Onyx Studio 2 Circuit Board Replacement: 手順 4、 2の画像 2
    • Remove the four wires connecting the front and back panels.
    • Pinch the connector tab and pull gently upwards.
    • Repeat for the other three connectors.
  5. Harman Kardon Onyx Studio 2 Circuit Board Replacement, Control Board: 手順 5、 1の画像 1
    • Pull the silicone button band off of the outer edge of the speaker.
  6. Harman Kardon Onyx Studio 2 Circuit Board Replacement: 手順 6、 2の画像 1 Harman Kardon Onyx Studio 2 Circuit Board Replacement: 手順 6、 2の画像 2
    • Disconnect the two pressure connections from the circuit board.
  7. Harman Kardon Onyx Studio 2 Circuit Board Replacement: 手順 7、 2の画像 1 Harman Kardon Onyx Studio 2 Circuit Board Replacement: 手順 7、 2の画像 2
    • Gently remove the control board band by placing fingers in contact with it through the button openings.
    • Work from the outer edges in so as not to bend the band.
  8. Harman Kardon Onyx Studio 2 Circuit Board Replacement, Circuit Board: 手順 8、 2の画像 1 Harman Kardon Onyx Studio 2 Circuit Board Replacement, Circuit Board: 手順 8、 2の画像 2
    • Disconnect the remaining connectors from the circuit board.
    • Disconnect the Bluetooth antenna.
  9. Harman Kardon Onyx Studio 2 Circuit Board Replacement: 手順 9、 2の画像 1 Harman Kardon Onyx Studio 2 Circuit Board Replacement: 手順 9、 2の画像 2
    • Remove the four 10 mm T10 Torx screws.
    • Pull the circuit board out of the device as it is now free.
終わりに
11 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Alexandra Achtenberg
メンバー登録日: 02/02/17
2,051 ポイント
6のガイドは作成済み
チーム
USF Tampa, Team 16-5, Blackwell Spring 2017 USF Tampa, Team 16-5, Blackwell Spring 2017人のメンバー
USFT-BLACKWELL-S17S16G5
3 メンバー
24のガイドは作成済み
5 件のコメント
Where do I get another one
Adrian tlahuel - 返信
Where we buy the board?
Eric Therrien - 返信
Umm… this was rather anticlimactic. Last step was basically like “and now contemplate your life choices”.
markcendan - 返信
Where can I Buy a new hk onix studio Main board?
tecnologia en localizaciòn - 返信
My speaker was working great. I just disconnected my phone to make a call, put YouTube back on it was all mumbled & the big button in the back kept pulsing so fast.
Maureen Field - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 29
過去 30 日: 144
今までの合計 21,867
