メインコンテンツにスキップ
Harman Kardon Esquire Mini Speaker Replacement
必要な工具と部品
  1. Harman Kardon Esquire Mini Speaker Replacement, Front Panel: 手順 1、 1の画像 1
    • Using the plastic opening tool, to open the back panel of the device. Start on the longer sides to avoid bending the metal frame at the plug ports.
    • Push down on the plastic opening tool, and push the back panel, repeat this for the 4 sides of the device.
  2. Harman Kardon Esquire Mini Speaker Replacement: 手順 2、 1の画像 1
    • Using the PH0 screw driver, remove the 7.5 mm screws by turning in a counter-clockwise direction. There are 6 screws on the front panel.
    • Remove all of the 7.5 mm screws, by repeating the same step above. It is not necessary to remove the stand-leg.
    • After unscrewing the 7.5 mm screws, just lift the plastic and you will see the motherboard.
  3. Harman Kardon Esquire Mini Speaker Replacement, Speaker: 手順 3、 1の画像 1
    • Pull out the motherboard by removing 4 screws around the perimeter of the motherboard. Keep in mind the wires still attached to the speakers, so pull gently.
  4. Harman Kardon Esquire Mini Speaker Replacement: 手順 4、 1の画像 1
    • Using the PH0 screwdriver unscrew the screws, there is one 4 mm screw on each speaker.
    • Re-do the same steps above for the other speaker to remove it.
  5. Harman Kardon Esquire Mini Speaker Replacement: 手順 5、 1の画像 1
    • Remove the speaker by using the plastic opening tool. Apply a gentle upward force to remove it.
終わりに
15 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
yousef aljeemaz
メンバー登録日: 10/18/17
1,039 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team S1-G9, Cagle Fall 2017 USF Tampa, Team S1-G9, Cagle Fall 2017人のメンバー
USFT-CAGLE-F17S1G9
5 メンバー
5のガイドは作成済み
39 件のコメント
Where can i buy a new speaker for this sound box ? thanks… sizinojr@gmail.com
Sizino Santos - 返信
Did you ever find the replacement speaker? I need one too.
Thx.
Troy -
Thanks, I need speaker also, where can I buy.
mnyucel@yahoo.com
mnyucel - 返信
Hi, I also need to know where could get new replacement speaker.
Thanks
mezafernando23 -
Hi, I also need to know where could I get the replacement speaker.
Thanks
mezafernando23 -
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 27
過去 30 日: 146
今までの合計 18,985
