必要な工具と部品
It is best to open the case at the rear of the connectors.
The lid has plastic tabs (1) which are stuck in the base (2). They can be loosened by pushing the base outwzards with a flat screwdriver or similar tool.
The manufacturer did not intend for the case to be opened, so some damage to the case is to be expected. (3)
The hard disk can now be lifted out of the plastic housing. It is not attached any further.
Unscrew the side screws.
Remove the permanently attached cables and stickers from the grease plate.
Then pull the hard drive backwards with a little force.
Repeat the steps in order to reassemble your device.
2 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
