はじめに
If your Handspring Visor Edge is producing distorted audio or no sound at all, use this guide to replace the speaker.
To confirm that the faulty part is coming from the Handspring Visor Edge’s speaker, inspect the speaker port for debris that may be interfering with sound quality. A small buildup of dust can be removed using an ESD-safe brush or small dust blower.
Make sure your device is powered off before you begin.
必要な工具と部品
Open the Visor Edge placing the screen and the inner part of the flip cover face down on a flat surface such as a table
On the back of the PDA there is a tab connecting the flip cover to the device. Push gently on this tab trying to slide the cover upwards along the surface then lift the pieces apart to fully detach them
Remove the six 4.1 mm Phillips screws from the back plate using the #00 Phillips Scewdriver.
