メインコンテンツにスキップ
Handspring Visor Edge Speaker Replacement
必要な工具と部品
  1. Handspring Visor Edge Speaker Replacement, Flip Cover: 手順 1、 2の画像 1 Handspring Visor Edge Speaker Replacement, Flip Cover: 手順 1、 2の画像 2
    • Open the Visor Edge and place it on a table facing down.
    • Gently push the tab that connects the flip cover (top half) to the PDA (bottom half) upward, lift the pieces apart to detach them.
    • Do not pull on the flip cover in an attempt to remove it from the PDA.
  2. Handspring Visor Edge Speaker Replacement, Back Panel: 手順 2、 1の画像 1
    • Remove the six 4.1 mm Phillips screws from the back plate using the #00 Phillips Scewdriver.
  3. Handspring Visor Edge Speaker Replacement: 手順 3、 1の画像 1
    • Remove the gray back plate from the PDA.
  4. Handspring Visor Edge Speaker Replacement: 手順 4、 2の画像 1 Handspring Visor Edge Speaker Replacement: 手順 4、 2の画像 2
    • Remove the four 2.6 mm Philips screws that are on the sides of the frame.
    • Remove the 3.9 mm Philips screw holding the stylus holster to the frame.
  5. Handspring Visor Edge Speaker Replacement: 手順 5、 2の画像 1 Handspring Visor Edge Speaker Replacement: 手順 5、 2の画像 2
    • Remove the four 2.6 mm Philips screws on the top and bottom of the frame.
  6. Handspring Visor Edge Speaker Replacement: 手順 6、 1の画像 1
    • Gently remove the white frame from the back of the PDA.
  7. Handspring Visor Edge Speaker Replacement, Speaker: 手順 7、 1の画像 1
    • Gently pull off front cover.
  8. Handspring Visor Edge Speaker Replacement: 手順 8、 1の画像 1
    • Gently remove buttons by hand.
  9. Handspring Visor Edge Speaker Replacement: 手順 9、 1の画像 1
    • Pull off button board.
    • (The button board is located underneath the buttons).
  10. Handspring Visor Edge Speaker Replacement: 手順 10、 1の画像 1
    • Carefully remove the speaker by pulling on the body of the plug with a pair of tweezers, rocking it from side to side to ease it if necessary.
    • Pull in the same direction as the individual wires are running and make sure to evenly on the full width of the cable so that no individual wires are overly strained.
終わりに
作成者
5人の作成者と共同で作成されました。
Nick Lazarakis
メンバー登録日: 01/23/11
331 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 11-28, Maness Winter 2011 Cal Poly, Team 11-28, Maness Winter 2011人のメンバー
CPSU-MANESS-W11S11G28
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 792
