メインコンテンツにスキップ
Handspring Visor Edge Screen Replacement
必要な工具と部品
  1. Handspring Visor Edge Screen Replacement, Flip Cover: 手順 1、 2の画像 1 Handspring Visor Edge Screen Replacement, Flip Cover: 手順 1、 2の画像 2
    • Open the Visor Edge and place it on a table facing down.
    • Gently push the tab that connects the flip cover (top half) to the PDA (bottom half) upward, lift the pieces apart to detach them.
    • Do not pull on the flip cover in an attempt to remove it from the PDA.
  2. Handspring Visor Edge Screen Replacement, Back Panel: 手順 2、 1の画像 1
    • Remove the six 4.1 mm Phillips screws from the back plate using the #00 Phillips Scewdriver.
  3. Handspring Visor Edge Screen Replacement: 手順 3、 1の画像 1
    • Remove the gray back plate from the PDA.
  4. Handspring Visor Edge Screen Replacement: 手順 4、 2の画像 1 Handspring Visor Edge Screen Replacement: 手順 4、 2の画像 2
    • Remove the four 2.6 mm Philips screws that are on the sides of the frame.
    • Remove the 3.9 mm Philips screw holding the stylus holster to the frame.
  5. Handspring Visor Edge Screen Replacement: 手順 5、 2の画像 1 Handspring Visor Edge Screen Replacement: 手順 5、 2の画像 2
    • Remove the four 2.6 mm Philips screws on the top and bottom of the frame.
  6. Handspring Visor Edge Screen Replacement: 手順 6、 1の画像 1
    • Gently remove the white frame from the back of the PDA.
  7. Handspring Visor Edge Screen Replacement, Screen: 手順 7、 1の画像 1
    • Place the PDA front face up.
    • Gently pull off the front cover.
  8. Handspring Visor Edge Screen Replacement: 手順 8、 2の画像 1 Handspring Visor Edge Screen Replacement: 手順 8、 2の画像 2
    この手順で使用する道具:
    購入する
    • Flip over the PDA.
    • Use the tweezers to remove the ribbon cable attaching the screen to the circuit board.
  9. Handspring Visor Edge Screen Replacement: 手順 9、 2の画像 1 Handspring Visor Edge Screen Replacement: 手順 9、 2の画像 2
    • Wedge the spudger in between the glass and the metal frame.
    • Slide the spudger down the length of the screen to detach from the frame.
    • With your hands, pry the screen up from the detached side. The screen will pop off.
終わりに
作成者
8人の作成者と共同で作成されました。
Christian Valoria
メンバー登録日: 01/23/11
201 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 11-28, Maness Winter 2011 Cal Poly, Team 11-28, Maness Winter 2011人のメンバー
CPSU-MANESS-W11S11G28
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 18
今までの合計 1,564
