はじめに
Welcome to the Handspring Visor Edge Battery Replacement Guide. In this manual, you'll find step-by-step instructions to efficiently replace the battery of your device. Whether you're a tech pro or a beginner, follow these simple steps to breathe new life into your Visor Edge. Lets Get Started!
必要な工具と部品
Open the Visor Edge and place it on a table facing down.
Gently push the tab that connects the flip cover (top half) to the PDA (bottom half) upward, lift the pieces apart to detach them.
Remove the six 4.1 mm Phillips screws from the back plate using the #00 Phillips Scewdriver.
