メインコンテンツにスキップ
Handheld Toilet Bidet Sprayer Replacement
必要な工具と部品
  1. Handheld Toilet Bidet Sprayer Replacement, Handheld Toilet Bidet Sprayer: 手順 1、 1の画像 1
    • Turn off the toilet water valve by turning the knob clockwise.
  2. Handheld Toilet Bidet Sprayer Replacement: 手順 2、 1の画像 1
    • Flush the toilet until no water is left in the tank.
  3. Handheld Toilet Bidet Sprayer Replacement: 手順 3、 1の画像 1
    • Place a towel under the tank incase of any water drops.
  4. Handheld Toilet Bidet Sprayer Replacement: 手順 4、 1の画像 1
    • Unscrew the water supply line from the T-connector by turning the knob counterclockwise.
  5. Handheld Toilet Bidet Sprayer Replacement: 手順 5、 1の画像 1
    • Unscrew the hose from the T-connector by turning the knob counterclockwise.
  6. Handheld Toilet Bidet Sprayer Replacement: 手順 6、 1の画像 1
    • Unscrew the T-connector from the toilet by turning the knob counterclockwise.
  7. Handheld Toilet Bidet Sprayer Replacement: 手順 7、 3の画像 1 Handheld Toilet Bidet Sprayer Replacement: 手順 7、 3の画像 2 Handheld Toilet Bidet Sprayer Replacement: 手順 7、 3の画像 3
    • Install the toilet sprayer's rubber on the water supply hose from the side that is causing a water leak. This will stop water leaking from the hose.
  8. Handheld Toilet Bidet Sprayer Replacement: 手順 8、 1の画像 1
    • Screw the T-connector back on the toilet by turning the knob clockwise.
    • Be careful not to cross the threads.
  9. Handheld Toilet Bidet Sprayer Replacement: 手順 9、 1の画像 1
    • Screw the water supply nut onto the bottom of the T-connector by turning the knob clockwise. Make sure it is firmly hand tight.
  10. Handheld Toilet Bidet Sprayer Replacement: 手順 10、 1の画像 1
    • Screw the water supply hose back on the T-connector by turning the knob clockwise. Be sure not to over tighten the nut.
  11. Handheld Toilet Bidet Sprayer Replacement: 手順 11、 1の画像 1
    • Turn on the toilet water valve by turning the knob counterclockwise. now, you can test your water and spray it through the hose. Make sure there is no water leaking.
    Hi,
    I have installed a handheld bidet like shown and having issues with pressure coming out of the handheld sprayer.
    The water pressure that comes out of the handheld sprayer is very low , but if I flush the toilet, while the cistern is refilling the pressure and sprayer works fine. As soon as the cistern is full the pressure drops and the and sprayer stops working. Thoughts?
    joseph.a.kobier - 返信
ゴール
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Almuhannad Althurwi
メンバー登録日: 06/29/18
201 ポイント
1ガイドが承認済み
チーム
2 件のコメント
If this is used as a bidet, wouldn’t the water be awfully cold? Almost too invigorating. If just used to help clean the toilet, okay.
Pete
Pete Chisteckoff - 返信
Same concern.
Nuke Engineer -
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 19
過去 30 日: 134
今までの合計 9,907
