メインコンテンツにスキップ
Hamilton Beach Food Processor 70740 Motor/Cord Replacement
アーカイブされたガイド
このガイドは将来的な使用のためにのみ保存されてます。ご自身の修理作業には更新バージョンをご利用ください。
必要な工具と部品
  1. 注意: 手順 1-5 は、作業進行中としてマークされている ガイド から引用されています。
    Hamilton Beach Food Processor 70740 Motor/Cord Replacement, Base Removal: 手順 1、 3の画像 1 Hamilton Beach Food Processor 70740 Motor/Cord Replacement, Base Removal: 手順 1、 3の画像 2 Hamilton Beach Food Processor 70740 Motor/Cord Replacement, Base Removal: 手順 1、 3の画像 3
    • Hold the food processor upside down and remove the two screws indicated with a screwdriver. Once unscrewed, remove the two rubber suction pads.
  2. Hamilton Beach Food Processor 70740 Motor/Cord Replacement: 手順 2、 2の画像 1 Hamilton Beach Food Processor 70740 Motor/Cord Replacement: 手順 2、 2の画像 2
    • Use a spudger to remove the 4 rubber base pads located at the corners of the device.
  3. Hamilton Beach Food Processor 70740 Motor/Cord Replacement: 手順 3、 1の画像 1
    • Unscrew all 4 screws that are located beneath the pads with a screwdriver and remove the plastic grey base.
  4. Hamilton Beach Food Processor 70740 Motor/Cord Replacement: 手順 4、 1の画像 1
    • Remove the screws indicated with a screw driver.
  5. Hamilton Beach Food Processor 70740 Motor/Cord Replacement: 手順 5、 1の画像 1
    • Remove the two screws behind the knob with a screwdriver.
  6. Hamilton Beach Food Processor 70740 Motor/Cord Replacement, Motor/Cord: 手順 6、 1の画像 1
    • Use a regular nylon spudger to remove the plastic caps at these locations with moderate pressure.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Apply pressure at the edge of the plastic cap circles. Apply stress elsewhere may damage the device.
    • Note that the plastic caps are glued
  7. Hamilton Beach Food Processor 70740 Motor/Cord Replacement: 手順 7、 1の画像 1
    • Remove the 4 screws located under the plastic caps with a screw driver.
  8. Hamilton Beach Food Processor 70740 Motor/Cord Replacement: 手順 8、 2の画像 1 Hamilton Beach Food Processor 70740 Motor/Cord Replacement: 手順 8、 2の画像 2
    • Lift and remove the plastic gears at the center of the device.
    • Remove any grease residue underneath the plastic gears.
  9. Hamilton Beach Food Processor 70740 Motor/Cord Replacement: 手順 9、 2の画像 1 Hamilton Beach Food Processor 70740 Motor/Cord Replacement: 手順 9、 2の画像 2
    • Remove the remaining screws to unhinge the motor located at the center of the device using a screw driver.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
David Gedeon
メンバー登録日: 09/17/15
806 ポイント
6のガイドは作成済み
チーム
IUPUI, Team 1-1, Baechle Fall 2015 IUPUI, Team 1-1, Baechle Fall 2015人のメンバー
IUPUI-BAECHLE-F15S1G1
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 217
