メインコンテンツにスキップ
Hamilton Beach 25460Z Thermal Switch Replacement
必要な工具と部品
  1. Hamilton Beach 25460Z Thermal Switch Replacement, Plug Wiring: 手順 1、 2の画像 1 Hamilton Beach 25460Z Thermal Switch Replacement, Plug Wiring: 手順 1、 2の画像 2
    • Unplug your device before proceeding with disassembly.
    • Remove the four 14mm screws from the bottom of the Panini Press using the T10 Screwdriver.
  2. Hamilton Beach 25460Z Thermal Switch Replacement: 手順 2、 1の画像 1
    • Lift up the plastic cover to expose the plug wiring.
    • Mark the plug wire connected to the red wire with a piece of tape. This will be used as a reference for reassembly.
  3. Hamilton Beach 25460Z Thermal Switch Replacement: 手順 3、 3の画像 1 Hamilton Beach 25460Z Thermal Switch Replacement: 手順 3、 3の画像 2 Hamilton Beach 25460Z Thermal Switch Replacement: 手順 3、 3の画像 3
    • Use the pliers to pinch the widest point of the cap. This should be done opposite of the already existing crimps.
    • Slide off the white cap.
    • Repeat these steps for the second white cap.
  4. Hamilton Beach 25460Z Thermal Switch Replacement: 手順 4、 2の画像 1 Hamilton Beach 25460Z Thermal Switch Replacement: 手順 4、 2の画像 2
    • Remove the two rubber screw covers from the bottom of the Panini Press.
    • Remove the four uncovered 10mm screws with the PH2 Screwdriver.
  5. Hamilton Beach 25460Z Thermal Switch Replacement: 手順 5、 2の画像 1 Hamilton Beach 25460Z Thermal Switch Replacement: 手順 5、 2の画像 2
    • Lift the plastic lower heating element up and place to the side for reassembly. You have now disconnected the plug wiring completely.
  6. Hamilton Beach 25460Z Thermal Switch Replacement, Thermal Switch: 手順 6、 2の画像 1 Hamilton Beach 25460Z Thermal Switch Replacement, Thermal Switch: 手順 6、 2の画像 2
    • Remove the two 10mm screws connecting the thermal switch with the PH2 Screwdriver and a bit of force.
    • These screws may be difficult to remove.
  7. Hamilton Beach 25460Z Thermal Switch Replacement: 手順 7、 1の画像 1
    • De-solder the connection between the wires and the thermal switch.
    • Refer to this page if you need to brush up on your soldering skills.
    • Replace the thermal switch.
    • The lead on the red (with the small hole), marked in red, connects to the white wire.
    • The lead on the right, marked in blue, connects to the blue wire.
終わりに
作成者
3人の作成者と共同で作成されました。
Forrest Rodeman
メンバー登録日: 02/01/15
318 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 6-27, Amido Winter 2015 Cal Poly, Team 6-27, Amido Winter 2015人のメンバー
CPSU-AMIDO-W15S6G27
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 18
今までの合計 1,718
