この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This is a straight-forward process that requires removal of a few screws and two wire caps.
必要な工具と部品
Remove the four 14mm screws from the bottom of the Panini Press using the T10 Screwdriver.
To reassemble your device, follow these instructions in reverse order. Make sure to correctly replace the wires using tape you placed earlier as a reference.
2 の人々がこのガイドを完成させました。
