はじめに
This is a straight-forward process that requires removal of a few screws and two wire caps.
必要な工具と部品
Remove the four 14mm screws from the bottom of the Panini Press using the T10 Screwdriver.
もう少しです!
To reassemble your device, follow these instructions in reverse order. Make sure to correctly replace the wires using tape you placed earlier as a reference.
終わりに
2 の人々がこのガイドを完成させました。
