メインコンテンツにスキップ
Hair Dryer Fan/ Motor Assembly Replacement
必要な工具と部品
  1. Hair Dryer Fan/ Motor Assembly Replacement, Nozzle: 手順 1、 2の画像 1 Hair Dryer Fan/ Motor Assembly Replacement, Nozzle: 手順 1、 2の画像 2
    • Remove the black air concentrating nozzle by gently twisting and pulling the nozzle.
    • If nozzle is not attached, skip to next step.
  2. Hair Dryer Fan/ Motor Assembly Replacement, Grating: 手順 2、 1の画像 1
    • Using a screwdriver, remove the screw located underneath the air concentrating nozzle. This screw attaches the hair dryer body to the hair dryer grating.
    • For most hair dryers, use a Phillips #1 screwdriver. For hair dryers with smaller screws, consider using a Phillips #00 screwdriver.
  3. Hair Dryer Fan/ Motor Assembly Replacement: 手順 3、 1の画像 1
    • Detach the hair dryer grating from the body by gently twisting the grating from side to side.
  4. Hair Dryer Fan/ Motor Assembly Replacement: 手順 4、 1の画像 1
    • Separate the hair dryer grating into the three pieces seen in the image.
  5. Hair Dryer Fan/ Motor Assembly Replacement, Fan/ Motor Assembly: 手順 5、 1の画像 1
    • Locate the screws on the handle and remove with a Phillips screwdriver.
  6. Hair Dryer Fan/ Motor Assembly Replacement: 手順 6、 1の画像 1
    • Carefully separate the plastic case with the Plastic Opening Tool.
  7. Hair Dryer Fan/ Motor Assembly Replacement: 手順 7、 1の画像 1
    • After removing the plastic case, locate the fan towards the back of the hair dryer.
  8. Hair Dryer Fan/ Motor Assembly Replacement: 手順 8、 1の画像 1
    • Remove the screw that is holding the fan to the motor using a Phillips screwdriver.
  9. Hair Dryer Fan/ Motor Assembly Replacement: 手順 9、 1の画像 1
    • Remove the screws holding the motor to the casing using a Phillips screwdriver.
    • NOTE: This may be unnecessary if the fan can be removed without using a screwdriver.
  10. Hair Dryer Fan/ Motor Assembly Replacement: 手順 10、 1の画像 1
    • Isolate the fan from the rest of the dryer.
    • Remove the screws holding the motor in place. Replace with the new component.
  11. Hair Dryer Fan/ Motor Assembly Replacement: 手順 11、 1の画像 1
    • Solder the wires to the motor. Refer to the soldering page below, which will help you replace this component.
    • Soldering Skills
終わりに
2 の人々がこのガイドを完成させました。
作成者
9人の作成者と共同で作成されました。
Mitch
メンバー登録日: 10/04/12
34 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 24-29, Regan Fall 2012 Cal Poly, Team 24-29, Regan Fall 2012人のメンバー
CPSU-REGAN-F12S24G29
5 メンバー
11のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 13
過去 30 日: 51
今までの合計 16,577
