メインコンテンツにスキップ
Hair Dryer Button Switchboard Replacement
必要な工具と部品
  1. Hair Dryer Button Switchboard Replacement, Nozzle: 手順 1、 2の画像 1 Hair Dryer Button Switchboard Replacement, Nozzle: 手順 1、 2の画像 2
    • Remove the black air concentrating nozzle by gently twisting and pulling the nozzle.
    • If nozzle is not attached, skip to next step.
  2. Hair Dryer Button Switchboard Replacement, Grating: 手順 2、 1の画像 1
    • Using a screwdriver, remove the screw located underneath the air concentrating nozzle. This screw attaches the hair dryer body to the hair dryer grating.
    • For most hair dryers, use a Phillips #1 screwdriver. For hair dryers with smaller screws, consider using a Phillips #00 screwdriver.
  3. Hair Dryer Button Switchboard Replacement: 手順 3、 1の画像 1
    • Detach the hair dryer grating from the body by gently twisting the grating from side to side.
  4. Hair Dryer Button Switchboard Replacement: 手順 4、 1の画像 1
    • Separate the hair dryer grating into the three pieces seen in the image.
  5. Hair Dryer Button Switchboard Replacement, Button Switchboard: 手順 5、 1の画像 1
    • Using a Phillips #1 Screwdriver, remove the screws located on the hair dryer handle.
  6. Hair Dryer Button Switchboard Replacement: 手順 6、 1の画像 1
  7. Hair Dryer Button Switchboard Replacement: 手順 7、 1の画像 1
    • The hairdryer is now disassembled. The fan, motor, heating element cover, and internal wiring are exposed.
    • Please be careful around these parts of the hairdryer. Even if the device is off, they may be warm to the touch.
    • This is the TURBO button.
    • This is the SWITCHBOARD button.
  8. Hair Dryer Button Switchboard Replacement: 手順 8、 1の画像 1
    • Gently pull the turbo button away from the hair dryer body.
    • If the turbo setting is still not working after you replace the switchboard, consider using soldering techniques to replace the turbo button. It may be why the hairdryer is not working properly, too.
  9. Hair Dryer Button Switchboard Replacement: 手順 9、 1の画像 1
    • Gently pull the button switchboard away from the hair dryer body.
    • Using a desoldering wick and a soldering iron, desolder the wires. This will help with the electrical connection issues that may be occurring.
    • Refer to the following page for desoldering instructions: Soldering Skills
終わりに
ある他の人がこのガイドを完成しました。
作成者
11人の作成者と共同で作成されました。
Mitch
メンバー登録日: 10/04/12
34 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 24-29, Regan Fall 2012 Cal Poly, Team 24-29, Regan Fall 2012人のメンバー
CPSU-REGAN-F12S24G29
5 メンバー
11のガイドは作成済み
コメント 1 件
I have a hairdryer with loose wire. Can you help me to find where the wire should be welded?
ziad musa - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 9
過去 30 日: 45
今までの合計 8,913
