メインコンテンツにスキップ
はじめに
This guide will explain how to remove and install the keyboard slider on the HTC Wizard 200.
The keyboard slider slides out from the right side of the phone to reveal a QWERTY keyboard. The main use of the keyboard is for texting, as well as all typing on the phone.
The keys should type out the correct letter when typing and not repeat letters when pressed once. The slider should smoothly move in and out of the body without catching or sticking. If these symptoms are present, then the keyboard slider needs repairing.
パーツ
パーツは指定されていません。
  1. HTC Wizard 200 Keyboard Slider Replacement, Battery: 手順 1、 2の画像 1 HTC Wizard 200 Keyboard Slider Replacement, Battery: 手順 1、 2の画像 2
    • To expose the battery, remove the outer case with your fingernail.
    • Remove the battery by pulling the black tab.
    • Insert the flat end of the spudger into the two notches on the back of the camera cover and pry them up.
    • Work the spudger around the edges of the camera cover until it comes off.
    • Remove the four 6 mm screws with the T5 Torx screwdriver.
    • One of the screws is under the "void" sticker.
  2. HTC Wizard 200 Keyboard Slider Replacement: 手順 5、 3の画像 1 HTC Wizard 200 Keyboard Slider Replacement: 手順 5、 3の画像 2 HTC Wizard 200 Keyboard Slider Replacement: 手順 5、 3の画像 3
    • Insert the flat end of an iFixit opening tool between the side and inner covers to create a gap.
    • Work the tool around the edges until all the clips release.
  3. HTC Wizard 200 Keyboard Slider Replacement: 手順 6、 2の画像 1 HTC Wizard 200 Keyboard Slider Replacement: 手順 6、 2の画像 2
    • Once all the clips are open, remove the inner panel from the phone.
    • Using tweezers, flip the connector latch away from the motherboard.
    • Detach the flexible connection from under the connector latch.
  4. HTC Wizard 200 Keyboard Slider Replacement: 手順 9、 1の画像 1
    • Slide the keyboard into the open position.
    • Lift the motherboard out of the case using the spudger.
    • Expose the underside of the motherboard using your hands.
  5. HTC Wizard 200 Keyboard Slider Replacement: 手順 11、 2の画像 1 HTC Wizard 200 Keyboard Slider Replacement: 手順 11、 2の画像 2
    • Remove the flexible connection from the motherboard.
    • Caution: Removing the connection too fast may cause damage to the connection and cables.
    • Remove the four 5mm screws with the T5 Torx screwdriver.
    • Remove the keyboard slider from the main body.
終わりに
ある他の人がこのガイドを完成しました。
Kyle Champ
メンバー登録日: 2011年10月03日
225 ポイント
12のガイドは作成済み
チーム
Cal Poly, Team 20-27, Maness Fall 2011 Cal Poly, Team 20-27, Maness Fall 2011人のメンバー
CPSU-MANESS-F11S20G27
4 メンバー
24のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 872
