メインコンテンツにスキップ
HTC Wizard 100 Speakers Replacement
必要な工具と部品
  1. HTC Wizard 100 Speakers Replacement, Battery: 手順 1、 2の画像 1 HTC Wizard 100 Speakers Replacement, Battery: 手順 1、 2の画像 2
    • Power the phone off.
    • Use your thumb to gently press downward and away from the camera to remove the battery cover.
  2. HTC Wizard 100 Speakers Replacement: 手順 2、 2の画像 1 HTC Wizard 100 Speakers Replacement: 手順 2、 2の画像 2
    • Pull on the plastic tab to release the battery.
  3. HTC Wizard 100 Speakers Replacement, Back Case: 手順 3、 2の画像 1 HTC Wizard 100 Speakers Replacement, Back Case: 手順 3、 2の画像 2
    • Use a plastic opening tool to remove the camera cover.
    • Work around the corners to avoid breaking the plastic clips that hold the camera cover on.
    • Lift the camera cover off of the phone.
  4. HTC Wizard 100 Speakers Replacement: 手順 4、 1の画像 1
    • Remove the stylus from the phone.
    • Remove the four 5.5 mm screws with the T6 Torx Screwdriver.
    • One of the screws might be under a sticker, which will void your warranty.
  5. HTC Wizard 100 Speakers Replacement: 手順 5、 3の画像 1 HTC Wizard 100 Speakers Replacement: 手順 5、 3の画像 2 HTC Wizard 100 Speakers Replacement: 手順 5、 3の画像 3
    • Be Careful! Do not insert the spudger in between the keyboard and screen. This could break the keyboard off the phone.
    • If your phone contains a memory card, you may want to remove it before proceeding with this step.
    • Insert spudger in the bottom corner as seen in the picture. Carefully slide the spudger from the bottom towards the top as seen in the second picture.
    • Lift the back case off completely.
    • The speakers might be dangling and unsecured.
  6. HTC Wizard 100 Speakers Replacement, Speakers: 手順 6、 2の画像 1 HTC Wizard 100 Speakers Replacement, Speakers: 手順 6、 2の画像 2
    • Grip the speaker connector with your thumb and finger and gently pull up.
    • Repeat for 2nd speaker.
終わりに
作成者
6人の作成者と共同で作成されました。
Taylor Stone
メンバー登録日: 10/06/11
45 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 20-28, Maness Fall 2011 Cal Poly, Team 20-28, Maness Fall 2011人のメンバー
CPSU-MANESS-F11S20G28
4 メンバー
15のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 576
