メインコンテンツにスキップ
HTC Wizard 100 Motherboard Replacement
必要な工具と部品
  1. HTC Wizard 100 Motherboard Replacement, Battery: 手順 1、 2の画像 1 HTC Wizard 100 Motherboard Replacement, Battery: 手順 1、 2の画像 2
    • Power the phone off.
    • Use your thumb to gently press downward and away from the camera to remove the battery cover.
  2. HTC Wizard 100 Motherboard Replacement: 手順 2、 2の画像 1 HTC Wizard 100 Motherboard Replacement: 手順 2、 2の画像 2
    • Pull on the plastic tab to release the battery.
  3. HTC Wizard 100 Motherboard Replacement, Back Case: 手順 3、 2の画像 1 HTC Wizard 100 Motherboard Replacement, Back Case: 手順 3、 2の画像 2
    • Use a plastic opening tool to remove the camera cover.
    • Work around the corners to avoid breaking the plastic clips that hold the camera cover on.
    • Lift the camera cover off of the phone.
  4. HTC Wizard 100 Motherboard Replacement: 手順 4、 1の画像 1
    • Remove the stylus from the phone.
    • Remove the four 5.5 mm screws with the T6 Torx Screwdriver.
    • One of the screws might be under a sticker, which will void your warranty.
  5. HTC Wizard 100 Motherboard Replacement: 手順 5、 3の画像 1 HTC Wizard 100 Motherboard Replacement: 手順 5、 3の画像 2 HTC Wizard 100 Motherboard Replacement: 手順 5、 3の画像 3
    • Be Careful! Do not insert the spudger in between the keyboard and screen. This could break the keyboard off the phone.
    • If your phone contains a memory card, you may want to remove it before proceeding with this step.
    • Insert spudger in the bottom corner as seen in the picture. Carefully slide the spudger from the bottom towards the top as seen in the second picture.
    • Lift the back case off completely.
    • The speakers might be dangling and unsecured.
  6. HTC Wizard 100 Motherboard Replacement, Speakers: 手順 6、 2の画像 1 HTC Wizard 100 Motherboard Replacement, Speakers: 手順 6、 2の画像 2
    • Grip the speaker connector with your thumb and finger and gently pull up.
    • Repeat for 2nd speaker.
  7. HTC Wizard 100 Motherboard Replacement, Camera: 手順 7、 1の画像 1
    • Locate the camera and pry off with the plastic opening tool or spudger.
  8. HTC Wizard 100 Motherboard Replacement, Motherboard: 手順 8、 1の画像 1
    • Remove the 3.4 mm black screw with the Phillips #000 screwdriver.
  9. HTC Wizard 100 Motherboard Replacement: 手順 9、 2の画像 1 HTC Wizard 100 Motherboard Replacement: 手順 9、 2の画像 2
    • Remove the plastic tape to reveal the connector.
    • Use your finger or plastic opening tool to flip the connector and release the cable.
  10. HTC Wizard 100 Motherboard Replacement: 手順 10、 2の画像 1 HTC Wizard 100 Motherboard Replacement: 手順 10、 2の画像 2
    • Use the plastic opening tool to carefully lift the motherboard off one corner at a time.
    • Lift the motherboard slowly away from the keyboard because there is a cable attached to bottom of the motherboard.
    • If the motherboard is not easily removed by pulling, then lift one side of the motherboard until you can see the attached cable. Then use the plastic opening tool to detach the cable from the motherboard.
終わりに
作成者
6人の作成者と共同で作成されました。
Eric W
メンバー登録日: 09/22/11
41 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 20-28, Maness Fall 2011 Cal Poly, Team 20-28, Maness Fall 2011人のメンバー
CPSU-MANESS-F11S20G28
4 メンバー
15のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 809
