Use a plastic opening tool to remove the camera cover.
Work around the corners to avoid breaking the plastic clips that hold the camera cover on.
Lift the camera cover off of the phone.
Remove the stylus from the phone.
Remove the four 5.5 mm screws with the T6 Torx Screwdriver.
One of the screws might be under a sticker, which will void your warranty.
Be Careful! Do not insert the spudger in between the keyboard and screen. This could break the keyboard off the phone.
If your phone contains a memory card, you may want to remove it before proceeding with this step.
Insert spudger in the bottom corner as seen in the picture. Carefully slide the spudger from the bottom towards the top as seen in the second picture.
Lift the back case off completely.
The speakers might be dangling and unsecured.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
