メインコンテンツにスキップ
HTC Vive Outer Shell Replacement
必要な工具と部品
  1. HTC Vive Outer Shell Replacement, Open the cable compartment: 手順 1、 3の画像 1 HTC Vive Outer Shell Replacement, Open the cable compartment: 手順 1、 3の画像 2 HTC Vive Outer Shell Replacement, Open the cable compartment: 手順 1、 3の画像 3
    • Be sure to power down and disconnect your Vive before beginning.
    • Place a finger on the top edge of the compartment cover assembly and slide the assembly toward the front of the Vive until it comes loose from the headset.
    • Lift the cover away from the headset and slide it up the cables until it's out of the way.
  2. HTC Vive Outer Shell Replacement, Unplug the HDMI cable: 手順 2、 2の画像 1 HTC Vive Outer Shell Replacement, Unplug the HDMI cable: 手順 2、 2の画像 2
    • Lift the HDMI cable straight up to unplug it from the headset.
  3. HTC Vive Outer Shell Replacement, Unplug the remaining cables: 手順 3、 3の画像 1 HTC Vive Outer Shell Replacement, Unplug the remaining cables: 手順 3、 3の画像 2 HTC Vive Outer Shell Replacement, Unplug the remaining cables: 手順 3、 3の画像 3
    • Repeat the lifting and unplugging process with the remaining USB, power, and audio cables.
  4. HTC Vive Outer Shell Replacement, Unscrew the outer shell: 手順 4、 3の画像 1 HTC Vive Outer Shell Replacement, Unscrew the outer shell: 手順 4、 3の画像 2 HTC Vive Outer Shell Replacement, Unscrew the outer shell: 手順 4、 3の画像 3
    • Use tweezers to remove the small stickers over the four screws securing the outer shell.
    • Use a T5 Torx driver to remove the four 3.4 mm-long screws securing the outer shell.
  5. HTC Vive Outer Shell Replacement, Remove the outer shell: 手順 5、 2の画像 1 HTC Vive Outer Shell Replacement, Remove the outer shell: 手順 5、 2の画像 2
    • Use the flat end of a spudger to pry up the top edge of the right half of the outer shell, behind the component cover and near the seam in the center, until it is unclipped from the headset.
  6. HTC Vive Outer Shell Replacement: 手順 6、 2の画像 1 HTC Vive Outer Shell Replacement: 手順 6、 2の画像 2
    • Grasp the right half the outer shell and pull it to the right and toward the front of the headset until you feel the clips on the front of the cover release.
    • If the shell is difficult to remove, try prying along the seam with the flat end of a spudger to release the clips.
  7. HTC Vive Outer Shell Replacement: 手順 7、 2の画像 1 HTC Vive Outer Shell Replacement: 手順 7、 2の画像 2
    • Slide the right side of the outer shell to the right and off of the headset.
  8. HTC Vive Outer Shell Replacement: 手順 8、 2の画像 1 HTC Vive Outer Shell Replacement: 手順 8、 2の画像 2
    • Repeat the last three steps for the left side of the outer shell and remove it.
終わりに
4 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Adam O'Camb
メンバー登録日: 04/11/15
196,116 ポイント
416のガイドは作成済み
5 件のコメント
I was dusting my pc and in the process tripped over the cable for my vive and cracked the front. Does anyone have an idea on how to get a new outer shell?
Adam Joseph - 返信
I also had the same issue with the front left side getting a crack. I contacted the VIVE support and they said they don’t sell and have no intention on selling parts. Nancy S. suggested sending it in for 6-8 weeks for repair. This option did not work for me so i bought a spare headset on Ebay for parts and did it myself. My advise is to not trust HTC service. I’ve heard many stories of headsets returning over 8 weeks back with nothing fixed.
Dan - 返信
That’s frustrating to hear. Hopefully the right to repair legislation changes this soon! Not providing parts to your customers is insane.
Richard -
Where do you buy the parts ?
xspitfire - 返信
As of now there is no reseller or seller of the plastic parts for the vive. I would suggest gluing the part back together with super glue or resin/epoxy or if you have the stuff make a 3d scan of it and 3d print a new one.
lolatron - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 18
今までの合計 3,314
