メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
  1. この手順は未翻訳です。 翻訳を手伝う。
    Turn over the Vive controller so that the bottom saucer is facing up. Use the T5 Torx screwdriver to remove three black 21mm screws from the bottom saucer. Use the T5 Torx screwdriver to remove three black 21mm screws from the bottom saucer.
    • Turn over the Vive controller so that the bottom saucer is facing up.
    • Use the T5 Torx screwdriver to remove three black 21mm screws from the bottom saucer.
  2. この手順は未翻訳です。 翻訳を手伝う。
    Use the nylon spudger to separate the top and bottom saucer covers all around the edges. Remove only the top saucer cover by pulling up with your hand.
    • Use the nylon spudger to separate the top and bottom saucer covers all around the edges.
    • Remove only the top saucer cover by pulling up with your hand.
  3. iPhone LCDスクリーン修理キット
    生涯保証付きの低コストオプション
    キット商品を見る
    品質ではなく、修理コストを削減しましょう。
    キット商品を見る
  4. この手順は未翻訳です。 翻訳を手伝う。
    Use the Phillips 00 screwdriver to remove the three silver 12.8mm screws from the exposed upper sensor panel. Use the Phillips 00 screwdriver to remove the three silver 12.8mm screws from the exposed upper sensor panel.
    • Use the Phillips 00 screwdriver to remove the three silver 12.8mm screws from the exposed upper sensor panel.
  5. この手順は未翻訳です。 翻訳を手伝う。
    Carefully pull away the bottom saucer cover with your hand. To aid in removing the saucer cover, squeeze the base of the controller with your other hand, as shown in the second image of this step. Squeezing will make the clips easier to release and help prevent them from breaking. To aid in removing the saucer cover, squeeze the base of the controller with your other hand, as shown in the second image of this step. Squeezing will make the clips easier to release and help prevent them from breaking.
    • Carefully pull away the bottom saucer cover with your hand.
    • To aid in removing the saucer cover, squeeze the base of the controller with your other hand, as shown in the second image of this step. Squeezing will make the clips easier to release and help prevent them from breaking.
ゴール
3 の人々がこのガイドを完成させました。
Ryan Grewohl
メンバー登録日: 2017年10月02日
507 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team S15-G5, Livingston Fall 2017 Cal Poly, Team S15-G5, Livingston Fall 2017人のメンバー
CPSU-LIVINGSTON-F17S15G5
4 メンバー
8のガイドは作成済み
3 件のコメント
Where do you get the replacement parts?
dmitri.walker - 返信
Vive dont less these parts we need to 3D print them its a Nightmare RN for business especially arcades
superseani2 - 返信
My controller only has 2 screws that are different sizes than a t5 and the 3rd is completely covered up by plastic. I have the sticky button problem, halp pls
bizkidjordan - 返信
コメントを追加
統計データを表示:
過去 24時間: 3
過去 7 日: 40
過去 30 日: 110
今までの合計 2,685
