メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
Use this guide to replace the HTC Vive controller saucer panels. You will need to remove these panels before you can access any other components of the controller. Remove the top and bottom saucer panels gently. The plastic clips that hold the saucer panels on can break if handled too roughly.
パーツ
パーツは指定されていません。
  1. Turn over the Vive controller so that the bottom saucer is facing up. Use the T5 Torx screwdriver to remove three black 21mm screws from the bottom saucer. Use the T5 Torx screwdriver to remove three black 21mm screws from the bottom saucer.
    • Turn over the Vive controller so that the bottom saucer is facing up.
    • Use the T5 Torx screwdriver to remove three black 21mm screws from the bottom saucer.
    Where can I buy new t5 21 mm screws? Mine are getting stripped out!
    jeremyvanwoerden - 返信
  2. Use the nylon spudger to separate the top and bottom saucer covers all around the edges. Remove only the top saucer cover by pulling up with your hand.
    • Use the nylon spudger to separate the top and bottom saucer covers all around the edges.
    • Remove only the top saucer cover by pulling up with your hand.
    My top saucer was REALLY stubborn. Don’t force it with your hand, use the spudger to separate it at the seam. Try not to poke your spudger in too deep, there are internals just inside the seam.
    trevorsklar - 返信
    The second time around, I learned why it was so stubborn. The picture suggests that you should start at the base of the saucer and work your way around, but that’s backwards.
    Start separating with your spudger at the distal side of the saucer and work your way toward the handle. Then for the last part, pull the piece up and away, like peeling a banana. See the second picture for the bottom half of the saucer, below. Do the same on the top.
    trevorsklar - 返信
  3. The Essential Toolkit
    コンパクト版iFixitキットの中で最も利便性の高いツール
    ショップを見る
    ショップを見る
  4. Use the Phillips 00 screwdriver to remove the three silver 12.8mm screws from the exposed upper sensor panel. Use the Phillips 00 screwdriver to remove the three silver 12.8mm screws from the exposed upper sensor panel.
    • Use the Phillips 00 screwdriver to remove the three silver 12.8mm screws from the exposed upper sensor panel.
    It’s Phillips 0, not 00.
    trevorsklar - 返信
    You do not need to remove these screws to remove the bottom saucer. They provide stability to the two halves of the donut.
    pacoavocado - 返信
    I had the same experience. Putting the screws back in made the bottom shell easier to remove.
    Nate Plamondon - 返信
    I concur, you don’t need to remove these screws to take the bottom shell off.
    I found mine had ph#000 screws size, not ph#00.
    Rocko the fixit cat - 返信
  5. Carefully pull away the bottom saucer cover with your hand. To aid in removing the saucer cover, squeeze the base of the controller with your other hand, as shown in the second image of this step. Squeezing will make the clips easier to release and help prevent them from breaking. To aid in removing the saucer cover, squeeze the base of the controller with your other hand, as shown in the second image of this step. Squeezing will make the clips easier to release and help prevent them from breaking.
    • Carefully pull away the bottom saucer cover with your hand.
    • To aid in removing the saucer cover, squeeze the base of the controller with your other hand, as shown in the second image of this step. Squeezing will make the clips easier to release and help prevent them from breaking.
    I found the re-assembly of this difficult until I concentrated on two areas - the lugs which go into the handle first, then the central ring. My earlier concern was for the optical sensors on the wings but these snapped into place easily as the central ring was manoeuvred.
    Doug - 返信
終わりに
3 の人々がこのガイドを完成させました。
Ryan Grewohl
メンバー登録日: 2017年10月02日
583 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team S15-G5, Livingston Fall 2017 Cal Poly, Team S15-G5, Livingston Fall 2017人のメンバー
CPSU-LIVINGSTON-F17S15G5
4 メンバー
8のガイドは作成済み
3 件のコメント
Where do you get the replacement parts?
dmitri.walker - 返信
Vive dont less these parts we need to 3D print them its a Nightmare RN for business especially arcades
superseani2 - 返信
My controller only has 2 screws that are different sizes than a t5 and the 3rd is completely covered up by plastic. I have the sticky button problem, halp pls
bizkidjordan - 返信
コメントを追加
統計データを表示:
過去 24時間: 4
過去 7 日: 14
過去 30 日: 71
今までの合計 3,410
