メインコンテンツにスキップ
HTC Vive Controller Battery Replacement
必要な工具と部品
  1. HTC Vive Controller Battery Replacement, Saucer Panels: 手順 1、 3の画像 1 HTC Vive Controller Battery Replacement, Saucer Panels: 手順 1、 3の画像 2 HTC Vive Controller Battery Replacement, Saucer Panels: 手順 1、 3の画像 3
    • Turn over the Vive controller so that the bottom saucer is facing up.
    • Use the T5 Torx screwdriver to remove three black 21mm screws from the bottom saucer.
    Where can I buy new t5 21 mm screws? Mine are getting stripped out!
    jeremyvanwoerden - 返信
    Where can you get replacement batteries?
    Mike Justice - 返信
    The middle bottom screw may have some form of warranty sticker on it if you have a Vive Pro wand (which is purple). Mine had this. Easy enough to remove and get on with it.
    sodiboo - 返信
  2. HTC Vive Controller Battery Replacement: 手順 2、 2の画像 1 HTC Vive Controller Battery Replacement: 手順 2、 2の画像 2
    • Use the nylon spudger to separate the top and bottom saucer covers all around the edges.
    • Remove only the top saucer cover by pulling up with your hand.
    My top saucer was REALLY stubborn. Don’t force it with your hand, use the spudger to separate it at the seam. Try not to poke your spudger in too deep, there are internals just inside the seam.
    trevorsklar - 返信
    The second time around, I learned why it was so stubborn. The picture suggests that you should start at the base of the saucer and work your way around, but that’s backwards.
    Start separating with your spudger at the distal side of the saucer and work your way toward the handle. Then for the last part, pull the piece up and away, like peeling a banana. See the second picture for the bottom half of the saucer, below. Do the same on the top.
    trevorsklar - 返信
  3. HTC Vive Controller Battery Replacement: 手順 3、 2の画像 1 HTC Vive Controller Battery Replacement: 手順 3、 2の画像 2
    • Use the Phillips 00 screwdriver to remove the three silver 12.8mm screws from the exposed upper sensor panel.
    It’s Phillips 0, not 00.
    trevorsklar - 返信
    You do not need to remove these screws to remove the bottom saucer. They provide stability to the two halves of the donut.
    pacoavocado - 返信
    I had the same experience. Putting the screws back in made the bottom shell easier to remove.
    Nate Plamondon - 返信
    I concur, you don’t need to remove these screws to take the bottom shell off.
    I found mine had ph#000 screws size, not ph#00.
    Rocko the fixit cat - 返信
    please do not remove the Phillips-head screws it is not necessary to remove them.
    Darkwolf Darkside - 返信
  4. HTC Vive Controller Battery Replacement: 手順 4、 3の画像 1 HTC Vive Controller Battery Replacement: 手順 4、 3の画像 2 HTC Vive Controller Battery Replacement: 手順 4、 3の画像 3
    • Carefully pull away the bottom saucer cover with your hand.
    • To aid in removing the saucer cover, squeeze the base of the controller with your other hand, as shown in the second image of this step. Squeezing will make the clips easier to release and help prevent them from breaking.
    I found the re-assembly of this difficult until I concentrated on two areas - the lugs which go into the handle first, then the central ring. My earlier concern was for the optical sensors on the wings but these snapped into place easily as the central ring was manoeuvred.
    Doug - 返信
    From what I can tell, there are two clicks on each side? one is quite easy, then the other one seems to require considerable force pushing down and on the side, I had to do it one side at a time and found two YouTube videos performing this step to use as reference. I have the vive pro wands and not the originals, so this may explain the difference. This felt very wrong to me.
    sodiboo - 返信
  5. HTC Vive Controller Battery Replacement, Front Panel: 手順 5、 2の画像 1 HTC Vive Controller Battery Replacement, Front Panel: 手順 5、 2の画像 2
    • Use the T5 Torx screwdriver to remove the two black 5.2mm screws on the back gray panel.
  6. HTC Vive Controller Battery Replacement: 手順 6、 1の画像 1
    • Turn over the Vive controller so that the exposed bottom saucer panel is facing up.
    • Use the T5 Torx screwdriver to remove the three black 5.2mm screws.
    Leave the middle screw where it is (the one being unscrewed in the picture). That screw holds the two halves of the photodiode assembly together, not the case.
    trevorsklar - 返信
    five screws… two at bottom
    andrew sauter - 返信
    I concur with trevosklar, don’t need to remove center screw to remove front panel (pad cover).
  7. HTC Vive Controller Battery Replacement: 手順 7、 2の画像 1 HTC Vive Controller Battery Replacement: 手順 7、 2の画像 2
    • Use the nylon spudger to separate the front panel gently by running the spudger around the edges of the handle.
    • Only separate the front panel around the edges. Do not try to completely remove the panel yet.
    • Gently lift the right side of the panel to the left.
  8. HTC Vive Controller Battery Replacement: 手順 8、 1の画像 1
    • Disconnect the upper ribbon cable gently by pulling the ribbon up and away from the motherboard with two fingers.
    • Do not try to disconnect the ribbon cables from the front panel.
    You do not have to remove the ribbon cables from the plugs…you can carefully work the battery holder around them and remove it…being very gentle. And the black part of the handle will stay attached to the cables and be in the way. But removing the cables does make it easier to access the area for the battery, just not completely necessary.
    controll - 返信
  9. HTC Vive Controller Battery Replacement: 手順 9、 2の画像 1 HTC Vive Controller Battery Replacement: 手順 9、 2の画像 2
    • Disconnect the middle ribbon cable gently by pulling the ribbon cable up and away from the motherboard with two fingers.
    where can one buy the ribbon cable.
    Luigi Munoz - 返信
  10. HTC Vive Controller Battery Replacement: 手順 10、 3の画像 1 HTC Vive Controller Battery Replacement: 手順 10、 3の画像 2 HTC Vive Controller Battery Replacement: 手順 10、 3の画像 3
    • Use the nylon spudger to lift the white tab by 90 degrees.
    • Disconnect the bottom ribbon cable gently by pulling the ribbon cable down with two fingers.
    Hallo what is the name of this conector because i Broker it
    Happy Forscher - 返信
    Yeah I did as instructed only to realize after that my gen 1 vive controller does not do that, and i desoldered the power button ribbon. That cable, does NOT detach on my model. destroyed.
    Algol Gaming -
    On my controllers, there was yellow tape over these? and in some other places as well? Why?
    sodiboo - 返信
  11. HTC Vive Controller Battery Replacement, Battery: 手順 11、 2の画像 1 HTC Vive Controller Battery Replacement, Battery: 手順 11、 2の画像 2
    • Use the Phillips 00 screwdriver to remove two black 2.8mm screws from the silver plate.
    • Use the Phillips 00 screwdriver to remove the black 5.8mm screw from the bottom right corner of the silver plate.
  12. HTC Vive Controller Battery Replacement: 手順 12、 1の画像 1
    • Remove the silver plate by pinching it with two fingers and lifting up.
    There is no plate on mine, only tape covering it.
    tamgoddess - 返信
    I found this to be true of mine as well (purchased 2018).
    Renjamin - 返信
    Same with mine, also purchased 2018. It seems the silver plate part can be skipped for later models.
    Slendy Nerd - 返信
  13. HTC Vive Controller Battery Replacement: 手順 13、 1の画像 1
    • Use the Phillips 00 screwdriver to remove the black 5.8mm screw from the top left of the battery frame.
  14. HTC Vive Controller Battery Replacement: 手順 14、 2の画像 1 HTC Vive Controller Battery Replacement: 手順 14、 2の画像 2
    • Use the T5 Torx screwdriver to remove the two silver 4.2mm screws from the bottom of the battery frame.
    On my controller these were Philips 000 5.8mm screws, the same as in the previous step.
    Daan Steenmeijer - 返信
    Second the above with a slight correction. Phillips 00.
    tamgoddess - 返信
    I also needed the Philips 000 for steps 11 - 14. Controller purchased in 2018.
    Renjamin - 返信
  15. HTC Vive Controller Battery Replacement: 手順 15、 2の画像 1 HTC Vive Controller Battery Replacement: 手順 15、 2の画像 2
    • Disconnect the three-pin cable gently by pinching the cable with two fingers and pulling up.
    Don't pull the battery cable! You risk pulling the pins out of the socket. Happened to me. I don't know how to do it properly but I had to use a fine flat screwdriver to try to get the socket out. It got a bit mangled unfortunately.
    Rob - 返信
  16. HTC Vive Controller Battery Replacement: 手順 16、 3の画像 1 HTC Vive Controller Battery Replacement: 手順 16、 3の画像 2 HTC Vive Controller Battery Replacement: 手順 16、 3の画像 3
    • Lift the battery frame to remove the battery from the Vive controller
    Suddenly, here the electronics of the saucer are gone, but there’s no previous step mentioning its removal. This is kind of important because loosening the ribbon cables attaching it to the mainboard is a bit finicky.
    Olav Reinert - 返信
終わりに
31 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Ryan Grewohl
メンバー登録日: 10/02/17
854 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team S15-G5, Livingston Fall 2017 Cal Poly, Team S15-G5, Livingston Fall 2017人のメンバー
CPSU-LIVINGSTON-F17S15G5
4 メンバー
51のガイドは作成済み
14 件のコメント
well if theres no parts…then theres no point…
altimmons - 返信
So, where do I get a replacement battery from? Does anyone know the part number?
scotty - 返信
This helped me ALOT. i had a controller stop charging or powering on. Decided to use this guide to pull just pull power and re seed the connection for the battery. The Battery connection IS NOT CLIPPED IN. TAPE holds down the connection to the terminals. So it can easy come loose over jolts and shocks or normal use
Mike Moutrie - 返信
battery is 3.85vdc 960ma
HTC model boplh100
3.69Whr
Part number 35H00244-00M
guido - 返信
With all the comments and steps, I easily took apart and rebuilt my controller. Thank you!!
Also, I used this cheap repair kit they sell at walmart if you dont have the tools and don't want to order them online.
https://www.walmart.com/ip/Hyper-Tough-T...
A K - 返信
My advice is to keep the connector on step 9 together and taped. I was trying to ease it out and the whole unit came right off… the connection and everything…My second controller I fixed in this way works 100%. Now I have to wait for my new controller from HTC.
A Brush With Death - 返信
Thanks! I had the vive when it was first released. my controller doesn’t have the silver brace over the battery connector only tape. It must have been revised. Re-seated the battery connector and it powered up
Brian Gonzales - 返信
Mine also did not have the sliver plate over the battery connector but it did have the seats for the screws so maybe the plate was eliminated. I broke one plastic clip learning the process in step 4 but there are enough screws that it won’t matter. I was able to R&R the battery without disconnecting the ribbon cables in steps 8, 9 & 10 which would have been somewhat risky so I think it was safer to leave them connected. Thanks to Guido for the part numbers. I bought them from mobile-part.com but the ship time was over a month to the US thanks to covid. I should have checked eBay. Many thanks to all posters of this article and comments.
Joe Schmo - 返信
Update: Just wanted to report that the batteries I received from mobile-part.com work well and both controllers now show all 4 green lights again when fully charged. My controllers were purchased in Dec. 2016.
Joe Schmo -
Intructions are excellent. One trick that I would add to make them complete is that when you buy new batteries they typically ship without the tray, so you will have to reuse the one that was removed from the controller. The battery is glued to the tray however and it also lacks battery removal taps. Prying or bending the battery is not recommended, as this could damage the battery and cause a runaway thermal event. The solution is simple and super low tech. Get a 12 inch long length of thread, ideally dental floss, and carefully and slowly pull the loop across the the glue strip. It takes less than 1 minute and, without needing a heat gun to loosen the glue, you will be able to remove the battery. Don’t worry about replacing the glue strip as the battery carrier holds it firmly in place without it.
Marc-Andre Renaud - 返信
The part number is B0PLH100. I found one on AliExpress
pvillano - 返信
Thanks so much for this guide. This was exactly what I needed.
Brandon Marks - 返信
Great guide. No faults at all. Well done. All works.
Bryn Lloyd - 返信
コメントを追加
統計データ:
過去 24時間: 16
過去 7 日: 83
過去 30 日: 517
今までの合計 37,185
