メインコンテンツにスキップ
HTC Vive Controller Battery Replacement
必要な工具と部品
  1. HTC Vive Controller Battery Replacement, Saucer Panels: 手順 1、 3の画像 1 HTC Vive Controller Battery Replacement, Saucer Panels: 手順 1、 3の画像 2 HTC Vive Controller Battery Replacement, Saucer Panels: 手順 1、 3の画像 3
    • Turn over the Vive controller so that the bottom saucer is facing up.
    • Use the T5 Torx screwdriver to remove three black 21mm screws from the bottom saucer.
  2. HTC Vive Controller Battery Replacement: 手順 2、 2の画像 1 HTC Vive Controller Battery Replacement: 手順 2、 2の画像 2
    • Use the nylon spudger to separate the top and bottom saucer covers all around the edges.
    • Remove only the top saucer cover by pulling up with your hand.
  3. HTC Vive Controller Battery Replacement: 手順 3、 2の画像 1 HTC Vive Controller Battery Replacement: 手順 3、 2の画像 2
    • Use the Phillips 00 screwdriver to remove the three silver 12.8mm screws from the exposed upper sensor panel.
  4. HTC Vive Controller Battery Replacement: 手順 4、 3の画像 1 HTC Vive Controller Battery Replacement: 手順 4、 3の画像 2 HTC Vive Controller Battery Replacement: 手順 4、 3の画像 3
    • Carefully pull away the bottom saucer cover with your hand.
    • To aid in removing the saucer cover, squeeze the base of the controller with your other hand, as shown in the second image of this step. Squeezing will make the clips easier to release and help prevent them from breaking.
  5. HTC Vive Controller Battery Replacement, Front Panel: 手順 5、 2の画像 1 HTC Vive Controller Battery Replacement, Front Panel: 手順 5、 2の画像 2
    • Use the T5 Torx screwdriver to remove the two black 5.2mm screws on the back gray panel.
  6. HTC Vive Controller Battery Replacement: 手順 6、 1の画像 1
    • Turn over the Vive controller so that the exposed bottom saucer panel is facing up.
    • Use the T5 Torx screwdriver to remove the three black 5.2mm screws.
  7. HTC Vive Controller Battery Replacement: 手順 7、 2の画像 1 HTC Vive Controller Battery Replacement: 手順 7、 2の画像 2
    • Use the nylon spudger to separate the front panel gently by running the spudger around the edges of the handle.
    • Only separate the front panel around the edges. Do not try to completely remove the panel yet.
    • Gently lift the right side of the panel to the left.
  8. HTC Vive Controller Battery Replacement: 手順 8、 1の画像 1
    • Disconnect the upper ribbon cable gently by pulling the ribbon up and away from the motherboard with two fingers.
    • Do not try to disconnect the ribbon cables from the front panel.
  9. HTC Vive Controller Battery Replacement: 手順 9、 2の画像 1 HTC Vive Controller Battery Replacement: 手順 9、 2の画像 2
    • Disconnect the middle ribbon cable gently by pulling the ribbon cable up and away from the motherboard with two fingers.
  10. HTC Vive Controller Battery Replacement: 手順 10、 3の画像 1 HTC Vive Controller Battery Replacement: 手順 10、 3の画像 2 HTC Vive Controller Battery Replacement: 手順 10、 3の画像 3
    • Use the nylon spudger to lift the white tab by 90 degrees.
    • Disconnect the bottom ribbon cable gently by pulling the ribbon cable down with two fingers.
  11. HTC Vive Controller Battery Replacement, Battery: 手順 11、 2の画像 1 HTC Vive Controller Battery Replacement, Battery: 手順 11、 2の画像 2
    • Use the Phillips 00 screwdriver to remove two black 2.8mm screws from the silver plate.
    • Use the Phillips 00 screwdriver to remove the black 5.8mm screw from the bottom right corner of the silver plate.
  12. HTC Vive Controller Battery Replacement: 手順 12、 1の画像 1
    • Remove the silver plate by pinching it with two fingers and lifting up.
  13. HTC Vive Controller Battery Replacement: 手順 13、 1の画像 1
    • Use the Phillips 00 screwdriver to remove the black 5.8mm screw from the top left of the battery frame.
  14. HTC Vive Controller Battery Replacement: 手順 14、 2の画像 1 HTC Vive Controller Battery Replacement: 手順 14、 2の画像 2
    • Use the T5 Torx screwdriver to remove the two silver 4.2mm screws from the bottom of the battery frame.
  15. HTC Vive Controller Battery Replacement: 手順 15、 2の画像 1 HTC Vive Controller Battery Replacement: 手順 15、 2の画像 2
    • Disconnect the three-pin cable gently by pinching the cable with two fingers and pulling up.
  16. HTC Vive Controller Battery Replacement: 手順 16、 3の画像 1 HTC Vive Controller Battery Replacement: 手順 16、 3の画像 2 HTC Vive Controller Battery Replacement: 手順 16、 3の画像 3
    • Lift the battery frame to remove the battery from the Vive controller
終わりに
31 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Ryan Grewohl
メンバー登録日: 10/02/17
854 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team S15-G5, Livingston Fall 2017 Cal Poly, Team S15-G5, Livingston Fall 2017人のメンバー
CPSU-LIVINGSTON-F17S15G5
4 メンバー
51のガイドは作成済み
14 件のコメント
well if theres no parts…then theres no point…
altimmons - 返信
So, where do I get a replacement battery from? Does anyone know the part number?
scotty - 返信
This helped me ALOT. i had a controller stop charging or powering on. Decided to use this guide to pull just pull power and re seed the connection for the battery. The Battery connection IS NOT CLIPPED IN. TAPE holds down the connection to the terminals. So it can easy come loose over jolts and shocks or normal use
Mike Moutrie - 返信
battery is 3.85vdc 960ma
HTC model boplh100
3.69Whr
Part number 35H00244-00M
guido - 返信
With all the comments and steps, I easily took apart and rebuilt my controller. Thank you!!
Also, I used this cheap repair kit they sell at walmart if you dont have the tools and don't want to order them online.
https://www.walmart.com/ip/Hyper-Tough-T...
A K - 返信
コメントを追加
統計データ:
過去 24時間: 12
過去 7 日: 100
過去 30 日: 459
今までの合計 37,321
