はじめに
このガイドを参照して、HTC Vive コントローラーのフロントパネルを取り外します。フロントパネルを外す際に、コネクタもしくはリボンケーブルを切断しないようにご注意ください。
必要な工具と部品
ナイロン製のスパッジャーを使って、端周辺に沿ってスライドしながら、上下ソーサーのカバーを乖離します。
上部ソーサーカバーを手で引き上げて外します。
My top saucer was REALLY stubborn. Don’t force it with your hand, use the spudger to separate it at the seam. Try not to poke your spudger in too deep, there are internals just inside the seam.
The second time around, I learned why it was so stubborn. The picture suggests that you should start at the base of the saucer and work your way around, but that’s backwards.
Start separating with your spudger at the distal side of the saucer and work your way toward the handle. Then for the last part, pull the piece up and away, like peeling a banana. See the second picture for the bottom half of the saucer, below. Do the same on the top.
#00 プラスドライバーを使って、露出した上部センサーパネルからシルバーの12.8mmネジを3本外します。
It’s Phillips 0, not 00.
You do not need to remove these screws to remove the bottom saucer. They provide stability to the two halves of the donut.
I had the same experience. Putting the screws back in made the bottom shell easier to remove.
I concur, you don’t need to remove these screws to take the bottom shell off.
I found mine had ph#000 screws size, not ph#00.
please do not remove the Phillips-head screws it is not necessary to remove them.
手で下部のソーサーカバーを引き離します。
From what I can tell, there are two clicks on each side? one is quite easy, then the other one seems to require considerable force pushing down and on the side, I had to do it one side at a time and found two YouTube videos performing this step to use as reference. I have the vive pro wands and not the originals, so this may explain the difference. This felt very wrong to me.
Viveコントローラーを裏返します。露出した下部のソーサーパネルが上向きになります。
T5トルクスドライバーを使って、黒い5.2mmネジを3本外します。
Leave the middle screw where it is (the one being unscrewed in the picture). That screw holds the two halves of the photodiode assembly together, not the case.
five screws… two at bottom
I concur with trevosklar, don’t need to remove center screw to remove front panel (pad cover).
上側のリボンケーブルを2本の指でマザーボードから引き上げるようにして、ゆっくりと取り外します。
You do not have to remove the ribbon cables from the plugs…you can carefully work the battery holder around them and remove it…being very gentle. And the black part of the handle will stay attached to the cables and be in the way. But removing the cables does make it easier to access the area for the battery, just not completely necessary.
2本の指でリボンケーブルを上に引っ張り、マザーボードから離すようにして、中央のリボンケーブルを静かに外します。
ナイロンのスパッジャーを使って、白いタブを90度持ち上げます。
下部リボンケーブルを2本の指で下に引っ張って、ゆっくりと外します。
Hallo what is the name of this conector because i Broker it
Yeah I did as instructed only to realize after that my gen 1 vive controller does not do that, and i desoldered the power button ribbon. That cable, does NOT detach on my model. destroyed.
このデバイスを再組み立てするには、インストラクションを逆の順番に従って作業を進めてください。
11 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
翻訳を始める ›
Where can I buy new t5 21 mm screws? Mine are getting stripped out!
jeremyvanwoerden - 返信
Where can you get replacement batteries?
Mike Justice - 返信
The middle bottom screw may have some form of warranty sticker on it if you have a Vive Pro wand (which is purple). Mine had this. Easy enough to remove and get on with it.
sodiboo - 返信
