メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
はじめに
Replacement of the HTC Touch Pro's motherboard.
パーツ
パーツは指定されていません。
  1. First, gently press on the back plate and push down toward the camera. First, gently press on the back plate and push down toward the camera.
    • First, gently press on the back plate and push down toward the camera.
  2. Use your finger to lift up the edge of the battery. Use your finger to lift up the edge of the battery.
    • Use your finger to lift up the edge of the battery.
  3. Remove the 4 screws using the T6 screw driver.
    • Remove the 4 screws using the T6 screw driver.
  4. Nintendo Switch 修理キット
    ゲームを再開するための、早くて簡単な修理キット
    Switch 修理キットページへ
    Switch 修理キットページへ
  5. Lift the plastic cover near the memory card slot. Lift the plastic cover near the memory card slot.
    • Lift the plastic cover near the memory card slot.
  6. Remove the two Phillips #00 screws from the backside of the screen.
    • Remove the two Phillips #00 screws from the backside of the screen.
  7. Insert a spudger or a plastic opening tool into the seam on the side of the phone. Gently pry apart the two halves of the phone.
    • Insert a spudger or a plastic opening tool into the seam on the side of the phone.
    • Gently pry apart the two halves of the phone.
  8. Gently unplug the connectors. Remove the screws with a 00 Phillips-head screwdriver.
    • Gently unplug the connectors.
    • Remove the screws with a 00 Phillips-head screwdriver.
  9. Gently lift the motherboard up using  a nylon spudger. BE AWARE OF THE ANTENNA.
    • Gently lift the motherboard up using a nylon spudger.
    • BE AWARE OF THE ANTENNA.
終わりに
Zhaowei Zhang
メンバー登録日: 2011年04月28日
112 ポイント
4のガイドは作成済み
チーム
CSU Los Angeles, Team 1-6, Nelson Spring 2011 CSU Los Angeles, Team 1-6, Nelson Spring 2011人のメンバー
CSULA-NELSON-S11S1G6
3 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 2,933
