はじめに
If the battery in your HTC Touch Pro 2 is not charging correctly, losing power quickly, or is damaged then it is time for a replacement. This guide would replace the battery for the HTC Touch Pro 2 to work at an improved pace.
Apply pressure and slide upward to remove back cover.
Lift the back cover up away from the phone.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
