メインコンテンツにスキップ
はじめに
Use this guide to replace a speaker that no longer outputs sound.
パーツ
パーツは指定されていません。
  1. HTC Thunderbolt Speaker Replacement, Rear Panel: 手順 1、 1の画像 1
    • Insert the plastic opening tool into the top of the Thunderbolt near the power button.
    • Gently pry up on the rear panel around the edges until it is loose.
  2. HTC Thunderbolt Speaker Replacement: 手順 2、 1の画像 1
    • Lift and remove the rear panel.
  3. HTC Thunderbolt Speaker Replacement, Battery: 手順 3、 2の画像 1 HTC Thunderbolt Speaker Replacement, Battery: 手順 3、 2の画像 2
    • Using the plastic opening tool, lift up the battery from the bottom near the kickstand.
    • Remove the battery from the inner frame.
  4. HTC Thunderbolt Speaker Replacement, Rear Frame: 手順 4、 1の画像 1
    • Remove the six Phillips screws from the perimeter of the rear frame.
    • By removing the screw with the "void" sticker on it, your Thunderbolt will no longer be covered under warranty.
  5. HTC Thunderbolt Speaker Replacement: 手順 5、 2の画像 1 HTC Thunderbolt Speaker Replacement: 手順 5、 2の画像 2
    • Insert the plastic opening tool into the bottom of the phone underneath the soft keys.
    • Gently pry up on the plastic cover by sliding the plastic opening tool across the bottom of the phone.
    • Remove the plastic cover.
    • The plastic cover will have adhesive on it making it difficult to remove.
  6. HTC Thunderbolt Speaker Replacement: 手順 6、 1の画像 1
    • Remove the two Phillips screws where the plastic cover was.
  7. HTC Thunderbolt Speaker Replacement: 手順 7、 2の画像 1 HTC Thunderbolt Speaker Replacement: 手順 7、 2の画像 2
    • Insert the plastic opening tool in between the screen and the frame on the side of the phone.
    • Slowly slide the the plastic opening tool along the side of the phone until the screen begins to separate from the frame.
    • Do the same for the opposite side of the phone.
  8. HTC Thunderbolt Speaker Replacement: 手順 8、 3の画像 1 HTC Thunderbolt Speaker Replacement: 手順 8、 3の画像 2 HTC Thunderbolt Speaker Replacement: 手順 8、 3の画像 3
    • Carefully separate the screen and phone from the rear frame, starting from the bottom.
    • Gently pull down on the phone and screen to fully separate it from the rear frame.
  9. HTC Thunderbolt Speaker Replacement, Rear Inner Frame: 手順 9、 1の画像 1
    • Remove the two Phillips screws securing rear inner frame to device.
  10. HTC Thunderbolt Speaker Replacement: 手順 10、 1の画像 1
    • Insert the plastic opening tool between the rear inner frame and the motherboard and slowly work your way around the device.
  11. HTC Thunderbolt Speaker Replacement: 手順 11、 2の画像 1 HTC Thunderbolt Speaker Replacement: 手順 11、 2の画像 2
    • Remove the rear inner frame from the rest of the device.
  12. HTC Thunderbolt Speaker Replacement, Speaker: 手順 12、 1の画像 1
    • Flip over rear inner frame.
  13. HTC Thunderbolt Speaker Replacement: 手順 13、 2の画像 1 HTC Thunderbolt Speaker Replacement: 手順 13、 2の画像 2
    • Pry out speaker with plastic opening tools.
    • You have now removed the speaker.
終わりに
Brandon Younger
メンバー登録日: 2013年01月17日
212 ポイント
8のガイドは作成済み
チーム
Cal Poly, Team 19-45, Regan Winter 2013 Cal Poly, Team 19-45, Regan Winter 2013人のメンバー
CPSU-REGAN-W13S19G45
4 メンバー
24のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 578
