この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
必要な工具と部品
Insert the plastic opening tool into the top of the Thunderbolt near the power button.
Gently pry up on the rear panel around the edges until it is loose.
Using the plastic opening tool, lift up the battery from the bottom near the kickstand.
Remove the battery from the inner frame.
Use your finger to push the MicroSD card in towards the top of the phone, allowing it to be released from the casing.
ある他の人がこのガイドを完成しました。
