メインコンテンツにスキップ
HTC Thunderbolt Motherboard Replacement
必要な工具と部品
  1. HTC Thunderbolt Motherboard Replacement, Rear Panel: 手順 1、 1の画像 1
    • Insert the plastic opening tool into the top of the Thunderbolt near the power button.
    • Gently pry up on the rear panel around the edges until it is loose.
  2. HTC Thunderbolt Motherboard Replacement: 手順 2、 1の画像 1
    • Lift and remove the rear panel.
  3. HTC Thunderbolt Motherboard Replacement, Battery: 手順 3、 2の画像 1 HTC Thunderbolt Motherboard Replacement, Battery: 手順 3、 2の画像 2
    • Using the plastic opening tool, lift up the battery from the bottom near the kickstand.
    • Remove the battery from the inner frame.
  4. HTC Thunderbolt Motherboard Replacement, MicroSD Card: 手順 4、 2の画像 1 HTC Thunderbolt Motherboard Replacement, MicroSD Card: 手順 4、 2の画像 2
    • Use your finger to push the MicroSD card in towards the top of the phone, allowing it to be released from the casing.
  5. HTC Thunderbolt Motherboard Replacement: 手順 5、 1の画像 1
    • Use tweezers to grab onto the MicroSD card and carefully remove it from the casing.
  6. HTC Thunderbolt Motherboard Replacement, Rear Frame: 手順 6、 1の画像 1
    • Remove the six Phillips screws from the perimeter of the rear frame.
    • By removing the screw with the "void" sticker on it, your Thunderbolt will no longer be covered under warranty.
  7. HTC Thunderbolt Motherboard Replacement: 手順 7、 2の画像 1 HTC Thunderbolt Motherboard Replacement: 手順 7、 2の画像 2
    • Insert the plastic opening tool into the bottom of the phone underneath the soft keys.
    • Gently pry up on the plastic cover by sliding the plastic opening tool across the bottom of the phone.
    • Remove the plastic cover.
    • The plastic cover will have adhesive on it making it difficult to remove.
  8. HTC Thunderbolt Motherboard Replacement: 手順 8、 1の画像 1
    • Remove the two Phillips screws where the plastic cover was.
  9. HTC Thunderbolt Motherboard Replacement: 手順 9、 2の画像 1 HTC Thunderbolt Motherboard Replacement: 手順 9、 2の画像 2
    • Insert the plastic opening tool in between the screen and the frame on the side of the phone.
    • Slowly slide the the plastic opening tool along the side of the phone until the screen begins to separate from the frame.
    • Do the same for the opposite side of the phone.
  10. HTC Thunderbolt Motherboard Replacement: 手順 10、 3の画像 1 HTC Thunderbolt Motherboard Replacement: 手順 10、 3の画像 2 HTC Thunderbolt Motherboard Replacement: 手順 10、 3の画像 3
    • Carefully separate the screen and phone from the rear frame, starting from the bottom.
    • Gently pull down on the phone and screen to fully separate it from the rear frame.
  11. HTC Thunderbolt Motherboard Replacement, LCD/Screen: 手順 11、 2の画像 1 HTC Thunderbolt Motherboard Replacement, LCD/Screen: 手順 11、 2の画像 2
    • Using the tip of an plastic opening tool flip up the tab holding the capacitive button ribbon cable.
    • Be careful opening these tabs as they are very easy to break.
    • Use a pair of tweezers to pull the capacitive button cable out of its socket.
  12. HTC Thunderbolt Motherboard Replacement: 手順 12、 2の画像 1 HTC Thunderbolt Motherboard Replacement: 手順 12、 2の画像 2
    • Lifting from the side where the ribbon was disconnected, flip over the motherboard.
    • Remove the black tape covering the tabs connecting the motherboard and LCD.
  13. HTC Thunderbolt Motherboard Replacement: 手順 13、 1の画像 1
    • Using the plastic opening tool pop up the two tabs connecting the LCD and motherboard.
  14. HTC Thunderbolt Motherboard Replacement: 手順 14、 2の画像 1 HTC Thunderbolt Motherboard Replacement: 手順 14、 2の画像 2
    • Once the tabs have been popped up, slowly pull the two pieces away from each other.
    • If there is resistance pulling apart the phone then a ribbon or tab has not been disconnected properly/completely.
  15. HTC Thunderbolt Motherboard Replacement, Motherboard: 手順 15、 1の画像 1
    • The motherboard should now be completely disconnected
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Vanessa
メンバー登録日: 01/18/13
60 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 19-45, Regan Winter 2013 Cal Poly, Team 19-45, Regan Winter 2013人のメンバー
CPSU-REGAN-W13S19G45
4 メンバー
24のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 1,725
