はじめに
Use this guide to remove the microSD prior to taking apart the rest of the device.
ツール
パーツ
パーツは指定されていません。
Insert the plastic opening tool into the top of the Thunderbolt near the power button.
Gently pry up on the rear panel around the edges until it is loose.
Using the plastic opening tool, lift up the battery from the bottom near the kickstand.
Remove the battery from the inner frame.
Use your finger to push the MicroSD card in towards the top of the phone, allowing it to be released from the casing.
もう少しです!
終わりに
