Using the plastic opening tool, lift up the battery from the bottom near the kickstand.
Remove the battery from the inner frame.
この手順で使用する道具:
購入する
Remove the six Phillips screws from the perimeter of the rear frame.
By removing the screw with the "void" sticker on it, your Thunderbolt will no longer be covered under warranty.
Insert the plastic opening tool into the bottom of the phone underneath the soft keys.
Gently pry up on the plastic cover by sliding the plastic opening tool across the bottom of the phone.
Remove the plastic cover.
The plastic cover will have adhesive on it making it difficult to remove.
Insert the plastic opening tool in between the screen and the frame on the side of the phone.
Slowly slide the the plastic opening tool along the side of the phone until the screen begins to separate from the frame.
Do the same for the opposite side of the phone.
Carefully separate the screen and phone from the rear frame, starting from the bottom.
Gently pull down on the phone and screen to fully separate it from the rear frame.
この手順で使用する道具:
購入する
Using the tip of an plastic opening tool flip up the tab holding the capacitive button ribbon cable.
Be careful opening these tabs as they are very easy to break.
Use a pair of tweezers to pull the capacitive button cable out of its socket.
Lifting from the side where the ribbon was disconnected, flip over the motherboard.
Remove the black tape covering the tabs connecting the motherboard and LCD.
Once the tabs have been popped up, slowly pull the two pieces away from each other.
If there is resistance pulling apart the phone then a ribbon or tab has not been disconnected properly/completely.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
