メインコンテンツにスキップ
HTC Surround Sim Card Replacement
必要な工具と部品
  1. HTC Surround Sim Card Replacement, Back Case: 手順 1、 2の画像 1 HTC Surround Sim Card Replacement, Back Case: 手順 1、 2の画像 2
    • Remove the back cover of the device to access the internal components of the HTC 7 Surround.
    • To remove the back cover, use the circular hole to lift up the cover while holding the front of the device down.
  2. HTC Surround Sim Card Replacement: 手順 2、 3の画像 1 HTC Surround Sim Card Replacement: 手順 2、 3の画像 2 HTC Surround Sim Card Replacement: 手順 2、 3の画像 3
    • Using a Phillips #00 screwdriver, remove the screws as directed.
  3. HTC Surround Sim Card Replacement: 手順 3、 1の画像 1
    • Separate the screen and back cover with the opening tool.
  4. HTC Surround Sim Card Replacement, SD Card: 手順 4、 3の画像 1 HTC Surround Sim Card Replacement, SD Card: 手順 4、 3の画像 2 HTC Surround Sim Card Replacement, SD Card: 手順 4、 3の画像 3
    • Look at the bottom right hand corner of the device and remove the silver tape covering the SD card slot with your fingers.
    • Insert the plastic opening tool directly underneath the orange surface below the SIM card until its removed from the surface of the device.
  5. HTC Surround Sim Card Replacement: 手順 5、 2の画像 1 HTC Surround Sim Card Replacement: 手順 5、 2の画像 2
    • To get to the attachment that the SD/SIM card is attached to; insert the plastic opening tool underneath the lower motherboard until it is removed from the bottom half of the device.
    • You will notice the SD/SIM card is attached to the lower motherboard by a yellow piece of tape. Remove the tape from the back of motherboard with your fingers.
  6. HTC Surround Sim Card Replacement, Sim Card: 手順 6、 1の画像 1
    • The SIM card slot will come off the device with the SD card slot and is ready to replace.
終わりに
作成者
2人の作成者と共同で作成されました。
Michael Ronning
メンバー登録日: 09/21/18
389 ポイント
4のガイドは作成済み
チーム
University of North Texas, Team S2-G5, Riccardelli Fall 2018 University of North Texas, Team S2-G5, Riccardelli Fall 2018人のメンバー
UNT-RICCARDELLI-F18S2G5
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 6
今までの合計 187
