メインコンテンツにスキップ
HTC Surround Motherboard Replacement
必要な工具と部品
  1. HTC Surround Motherboard Replacement, Back Case: 手順 1、 2の画像 1 HTC Surround Motherboard Replacement, Back Case: 手順 1、 2の画像 2
    • Remove the back cover of the device to access the internal components of the HTC 7 Surround.
    • To remove the back cover, use the circular hole to lift up the cover while holding the front of the device down.
  2. HTC Surround Motherboard Replacement: 手順 2、 3の画像 1 HTC Surround Motherboard Replacement: 手順 2、 3の画像 2 HTC Surround Motherboard Replacement: 手順 2、 3の画像 3
    • Using a Phillips #00 screwdriver, remove the screws as directed.
  3. HTC Surround Motherboard Replacement: 手順 3、 1の画像 1
    • Separate the screen and back cover with the opening tool.
  4. HTC Surround Motherboard Replacement, SD Card: 手順 4、 3の画像 1 HTC Surround Motherboard Replacement, SD Card: 手順 4、 3の画像 2 HTC Surround Motherboard Replacement, SD Card: 手順 4、 3の画像 3
    • Look at the bottom right hand corner of the device and remove the silver tape covering the SD card slot with your fingers.
    • Insert the plastic opening tool directly underneath the orange surface below the SIM card until its removed from the surface of the device.
  5. HTC Surround Motherboard Replacement: 手順 5、 2の画像 1 HTC Surround Motherboard Replacement: 手順 5、 2の画像 2
    • To get to the attachment that the SD/SIM card is attached to; insert the plastic opening tool underneath the lower motherboard until it is removed from the bottom half of the device.
    • You will notice the SD/SIM card is attached to the lower motherboard by a yellow piece of tape. Remove the tape from the back of motherboard with your fingers.
  6. HTC Surround Motherboard Replacement, Lower and Upper Motherboard: 手順 6、 1の画像 1
    • You will notice a ribbon that connects the upper and lower motherboard together. With your fingers, carefully pull up both ribbons that are attached to the lower motherboard.
  7. HTC Surround Motherboard Replacement: 手順 7、 1の画像 1
    • After you remove the ribbon, insert the plastic opening tool underneath the lower motherboard until it is released from the bottom of the device.
  8. HTC Surround Motherboard Replacement: 手順 8、 1の画像 1
    • For you to remove the upper motherboard, insert the plastic opening tool underneath the upper motherboard until it is removed from the bottom of the device (same as in step 2).
終わりに
作成者
2人の作成者と共同で作成されました。
Michael Ronning
メンバー登録日: 09/21/18
389 ポイント
4のガイドは作成済み
チーム
University of North Texas, Team S2-G5, Riccardelli Fall 2018 University of North Texas, Team S2-G5, Riccardelli Fall 2018人のメンバー
UNT-RICCARDELLI-F18S2G5
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 7
今までの合計 160
