このバージョンは誤った内容を含んでいる可能性があります。最新の承認済みスナップショットに切り替えてください。
必要な工具と部品
この手順は未翻訳です。 翻訳を手伝う。
Before lifting up the motherboard, be sure to release the 2nd jawbone connector. This one is for the touchscreen/digitizer. (Photo is with motherboard already out to show you exactly where it is.
With the flex cable removed you can now lift up on the motherboard. There is still a cable attached, but it is the touchscreen/digitizer cable. So, if you have a broken screen it IS ok if you break this cable.
この手順は未翻訳です。 翻訳を手伝う。
Starting at the top and then going down the sides, carefully insert a plastic pry too and begin to separate the touchscreen glass from the LCD assembly.
Be careful as you get to the bottom when removing the glass. There is a thin strip that needs to stay in tact.
When at the bottom you will notice a white strip. Do not tear this or the buttons on the bottom of your screen will not light up!
Go ahead and remove the glass completely.
この手順は未翻訳です。 翻訳を手伝う。
この手順で使用する道具:Microfiber Cleaning Cloths$3.99-
Remove the top layer of sticky black tape, then prep the LCD assembly and new touchscreen/digitizer with new adhesive--I just used thin strips of two-sided tape.
Using a microfiber cloth remove any dust from the LCD display.
Slide the new touchscreen/digitizer cable between the frame and LCD display.
Once the cable is through go ahead and remove all paper from adhesives and set the screen in place.
Now you can begin reconstructing your phone. Go ahead and go through the steps backwards.
Reattaching the cables is the trickiest part but not impossible.
29 の人々がこのガイドを完成させました。
2 件のコメント
Hello, good afternoon!
I wonder what the material used between the screen and the lcd display?
I realized that there is a sort of black film behind the touch screen. What would it be?
Jean Carlos
Jean Silva - 返信
