メインコンテンツにスキップ
HTC SMT 6175 Display Screen Replacement
必要な工具と部品
  1. HTC SMT 6175 Display Screen Replacement, Back Case: 手順 1、 1の画像 1
    • First, flip the phone over so that the back is facing upwards.
  2. HTC SMT 6175 Display Screen Replacement: 手順 2、 2の画像 1 HTC SMT 6175 Display Screen Replacement: 手順 2、 2の画像 2
    • Using both thumbs, push the back side of the phone's exterior up and remove the front face of the phone.
  3. HTC SMT 6175 Display Screen Replacement, Battery: 手順 3、 2の画像 1 HTC SMT 6175 Display Screen Replacement, Battery: 手順 3、 2の画像 2
    • Insert your finger or a pry tool into the slot above the battery. Remove it and set aside.
  4. HTC SMT 6175 Display Screen Replacement, Interior Back Case: 手順 4、 2の画像 1 HTC SMT 6175 Display Screen Replacement, Interior Back Case: 手順 4、 2の画像 2
    • To remove the case, use a small, pentagonal screwdriver to unscrew the 6 screws that can be found around the edges.
  5. HTC SMT 6175 Display Screen Replacement: 手順 5、 2の画像 1 HTC SMT 6175 Display Screen Replacement: 手順 5、 2の画像 2
    • Pull off the case.
    • This can be difficult. Just start pulling the back out from the front shell and, as it starts to lift up, continue moving around the phone until the whole back becomes free.
  6. HTC SMT 6175 Display Screen Replacement, Taking out the Motherboard: 手順 6、 1の画像 1
    • Next, unscrew the top screw using a small, Philips screwdriver.
    • Pull back the motherboard.
    • The LCD screen is still attached to the front side of the motherboard by a flexible ribbon cable and to the front case by an adhesive.
  7. HTC SMT 6175 Display Screen Replacement, Taking out the Display Screen: 手順 7、 2の画像 1 HTC SMT 6175 Display Screen Replacement, Taking out the Display Screen: 手順 7、 2の画像 2
    • Using a spudger, remove the display screen from its cell within the front case. Insert the spudger next to the LCD on the opposite side of where the motherboard is attached.
    • The LCD is attached with a sticky adhesive so it might be difficult to get off.
  8. HTC SMT 6175 Display Screen Replacement: 手順 8、 1の画像 1
    この手順で使用する道具:
    購入する
    • Place the motherboard down on top of the LCD. Using tweezers, remove the yellow piece of tape covering the end of the flat ribbon cable.
  9. HTC SMT 6175 Display Screen Replacement: 手順 9、 1の画像 1
    • Peel off the silver tape covering the flat ribbon cable. The motherboard is now free from the rest of the phone.
    • The sticky gray tape might have to be ripped in order to be removed because of its extreme stickiness.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Luke Plewa
メンバー登録日: 04/22/11
116 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 25-29, Garner Spring 2011 Cal Poly, Team 25-29, Garner Spring 2011人のメンバー
CPSU-GARNER-S11S25G29
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 9
今までの合計 1,673
