メインコンテンツにスキップ
HTC One X Top Speaker Replacement
必要な工具と部品
  1. HTC One X Top Speaker Replacement, Remove SIM card slot: 手順 1、 1の画像 1
    • Insert a safety pin, or other small object in the small opening next to the Sim card slot to remove the SIM card.
    • The Sim Card Slot is located at the top of the rear panel.
  2. HTC One X Top Speaker Replacement, Remove front panel: 手順 2、 2の画像 1 HTC One X Top Speaker Replacement, Remove front panel: 手順 2、 2の画像 2
    • Using a plastic opening tool, carefully separate the display screen from the rear panel.
    • The display assembly is a tight fit therefore the removal must be carried out carefully with firm, constant force being applied around the bottom corners and sides of the panel. Note that the top of the phone is underneath the panel, and will not come out.
    • If your display is cracked, take extra caution when separating the display from the rear panel to prevent further breakage.
    • Set aside the rear panel.
  3. HTC One X Top Speaker Replacement, Remove the top plastic panel: 手順 3、 2の画像 1 HTC One X Top Speaker Replacement, Remove the top plastic panel: 手順 3、 2の画像 2
    • Remove the five screws at the top of the panel using a Phillips head screwdriver.
    • Two 2.05mm Philips head screws
    • Three 2.44mm Philips head screws
    • Also remove the screws with the warranty stickers.
    • Once the screws are removed, gently remove the plastic cover using a plastic opening tool to detach the edges from the front panel.
    • Once you have disassembled your device, your warranty will no longer be valid.
  4. HTC One X Top Speaker Replacement, Remove antenna and disconnect the PCB board: 手順 4、 2の画像 1 HTC One X Top Speaker Replacement, Remove antenna and disconnect the PCB board: 手順 4、 2の画像 2
    • Remove the two screws at the bottom right corner of the front panel using a Phillips head screwdriver, as shown in the image.
    • Two 3.35mm Philips head screws
    • Use tweezers to disconnect the antenna from the logic board to the PCB board.
    • Remove the tape connected to the motherboard.
  5. HTC One X Top Speaker Replacement, Disconnect the battery and remove PCB board: 手順 5、 3の画像 1 HTC One X Top Speaker Replacement, Disconnect the battery and remove PCB board: 手順 5、 3の画像 2 HTC One X Top Speaker Replacement, Disconnect the battery and remove PCB board: 手順 5、 3の画像 3
    • Remove the tape holding the battery in place.
    • Gently lift the battery from the bottom using a plastic opening tool.
    • You may have to apply heat to melt the glue holding the battery in place.
    • Do not completely remove the battery yet
    • You can now disconnect the flex cable holding the PCB board place. Gently open the gates using tweezers or a plastic opening tool and use tweezers to slide the flex cable out.
    • Now that it's separated, remove and set aside the PCB board.
  6. HTC One X Top Speaker Replacement, Disconnect flex cables: 手順 6、 3の画像 1 HTC One X Top Speaker Replacement, Disconnect flex cables: 手順 6、 3の画像 2 HTC One X Top Speaker Replacement, Disconnect flex cables: 手順 6、 3の画像 3
    • Place the battery back into its original position once the PCB board has been removed
    • Use tweezers to disconnect the power button flex cables.
    • Disconnect the volume flex cable by opening the gate and then sliding the cable out using tweezers.
    • Disconnect the touchscreen flex cable
    • If repairing hard buttons, skip step 7.
  7. HTC One X Top Speaker Replacement, Remove logic board: 手順 7、 1の画像 1
    • Disconnect the remaining two flex cables in a similar manner before completely removing the logic board.
    • You may now remove the board safely
  8. HTC One X Top Speaker Replacement, Replace speaker: 手順 8、 1の画像 1
    • Carefully remove speaker at the top of your phone and replace it with the new speaker.
終わりに
5 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Nyles Peterson
メンバー登録日: 09/22/14
1,885 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 4-3, Brown Fall 2014 USF Tampa, Team 4-3, Brown Fall 2014人のメンバー
USFT-BROWN-F14S4G3
3 メンバー
12のガイドは作成済み
コメント 1 件
I like it ...
Ameen kt - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 3,267
