メインコンテンツにスキップ
HTC One X Plus Top Speaker Replacement
必要な工具と部品
  1. HTC One X Plus Top Speaker Replacement, Top Speaker: 手順 1、 1の画像 1
    • Hold down the power button to turn off your device.
    • Insert a pin, paper clip, or another similar object into the hole next to the micro sim card holder to remove it.
    • The SIM card slot is located on the top edge of the device.
  2. HTC One X Plus Top Speaker Replacement: 手順 2、 3の画像 1 HTC One X Plus Top Speaker Replacement: 手順 2、 3の画像 2 HTC One X Plus Top Speaker Replacement: 手順 2、 3の画像 3
    • Using plastic opening tools, pry open the bottom of the device.
    • You will hear clicking sounds as the sides of the device detach from the screen.
    • Once both sides are detached use the suction cup tool to remove the screen completely from the black casing.
  3. HTC One X Plus Top Speaker Replacement: 手順 3、 3の画像 1 HTC One X Plus Top Speaker Replacement: 手順 3、 3の画像 2 HTC One X Plus Top Speaker Replacement: 手順 3、 3の画像 3
    • Remove the five 2.4mm screws located around the camera using a Philips head screwdriver to remove the plastic cover.
    • Once you have disassembled your device the warranty will no longer be valid.
  4. HTC One X Plus Top Speaker Replacement: 手順 4、 3の画像 1 HTC One X Plus Top Speaker Replacement: 手順 4、 3の画像 2 HTC One X Plus Top Speaker Replacement: 手順 4、 3の画像 3
    • Use the J000 Philips screwdriver to remove the screws and remove the PCB board and antenna.
    • These are two 3.4mm Philips head screws found in the lower right corner of the phone.
  5. HTC One X Plus Top Speaker Replacement: 手順 5、 2の画像 1 HTC One X Plus Top Speaker Replacement: 手順 5、 2の画像 2
    • Pull out the power button flex cable using tweezers to disconnect from the phone.
    • Use the tweezers to then disconnect the touch screen flex cable.
  6. HTC One X Plus Top Speaker Replacement: 手順 6、 3の画像 1 HTC One X Plus Top Speaker Replacement: 手順 6、 3の画像 2 HTC One X Plus Top Speaker Replacement: 手順 6、 3の画像 3
    • Remove the battery connections to the logic board.
    • This is the six pin connector seen in the red box.
    • Pull the battery away to remove from the back of the screen.
  7. HTC One X Plus Top Speaker Replacement: 手順 7、 2の画像 1 HTC One X Plus Top Speaker Replacement: 手順 7、 2の画像 2
    • CAUTION: carefully remove the top speaker from the phone using tweezers.
終わりに
ある他の人がこのガイドを完成しました。
作成者
6人の作成者と共同で作成されました。
Jason Melo
メンバー登録日: 08/26/15
483 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 3-3, Eyestone Fall 2015 USF Tampa, Team 3-3, Eyestone Fall 2015人のメンバー
USFT-EYESTONE-F15S3G3
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 419
